[gdal-dev] Hillshade | Raster Band Rendering
Joaquim Luis
jluis at ualg.pt
Wed Mar 18 11:17:59 PDT 2015
> My objective is to create a hillshaded color-relief image of a DEM using
> commandline/programmatic means only, so the process >can be automated
> and combined within an existing GMT/GDAL workflow.
If your workflow includes GMT that you have a reach panoply of methods to
do shade illuminations. See man pages of grdgradient and grdhisteq.
Joaquim
> Currently, I can generate both hillshaded and color-relief rasters using
> gdaldem and combine them with Mapnik (using opacity) to >generate a my
> final rendered image. However, this process will use the min-max values
> in the grayscale hillshaded image.
> However, I can achieve an improved or sharper hillshaded image when I
> manually use QGIS to further process the hillshaded image >by:
> 1. Adding the hillshaded raster to QGIS, which applies by default the
> 'Cumulative count cut 2% - 98%' style.
> 2. Then export the hillshaded raster (with the cumulative count style
> applied) as a “Rendered Image”.
> I have annotated a screenshot here
> https://www.dropbox.com/s/ftzk7j2bmznuvjn/raster_band_rendering.png?dl=0
> hopefully >illustrating the
> 1. Improved hillshaded raster output from QGIS ('Cumulative count
> cut) compared with,
> 2. gdal+mapnik output (using min-max)
> So, is there an approach using gdal (or similar command-line tool/app)
> to achieve the “improved” hillshaded raster without the >“manual” QGIS
> step?
> As I see it, my options are:
> 1. Use gdalinfo with the “-hist” option to export the histogram of the
> hillshaded raster. I guess then I could maybe calculate the 2% >and 98%
> percentile(?) values and then manipulate the raster values using
> gdal_calc.py or something else. However, I’m no >statistician, so hoped
> there would be an out of the box solution?!
> 2. Maybe, I could use the python api for QGIS to import the hillshade,
> render, style and export back out. I’m sure this is possible, >but would
> require an additional python script.
> 3. Use another library or framework to achieve either of the above. I’ve
> researched python’s numpy library, which maybe I could do >the
> percentage calculation directly on the raster. Again, potentially tricky
> learning curve there…
> Any help or advice would greatly appreciated. If any help, the data I’m
> using is here
> https://www.dropbox.com/s/v0peaa3rzaqbhen/>raster_band_rendering.zip?dl=0
> Cheers
>> Gareth
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150318/38b47523/attachment-0001.html>
