[gdal-dev] ogr2ogr: Stuck trying to append lots of gml files to postgis tables
Stephen Woodbridge
woodbri at swoodbridge.com
Sun Mar 22 18:42:50 PDT 2015
No, I tried that also, but thank you for the suggestion. Running the
command like this resolved the problem as Even suggested.
PG_LIST_ALL_TABLES=YES ogr2ogr -update -append -f PostgreSQL
PG:"host=localhost user=postgres dbname=data_itn"
raw_itn/6360199_sn6103_2c7157.__gz
Thanks,
-Steve
On 3/22/2015 9:10 PM, Saulteau Don wrote:
> I wonder if part of the problem is that you haven't included the -update
> flag as well in the ogr2ogr command.
> ogr2ogr -update -append -f PostgreSQL PG:"host=localhost user=postgres
> dbname=data_itn" raw_itn/6360199_sn6103_2c7157.__gz
> Then like the warning says, there's also the lco option of -lco
> OVERWRITE=YES
> Which also overwrites an existing layer, but it will retain any VIEWS in
> the postgresql database that are built using the layer you're appending
> or updating.
> Donovan
> On Sun, Mar 22, 2015 at 1:33 PM, Stephen Woodbridge
> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
> On 3/22/2015 3:32 PM, Even Rouault wrote:
> Le dimanche 22 mars 2015 20:18:12, Stephen Woodbridge a écrit :
> Hi all,
> I have a directory of gml files. I can load any of them into
> postgis
> without a problem. What I'm having a problem with is
> appending each file
> to the existing tables. I'm using : GDAL 1.10.1, released
> 2013/08/26
> $ ogrinfo raw_itn/6360199_sn6103_2c7157.__gz
> Had to open data source read-only.
> INFO: Open of `raw_itn/6360199_sn6103___2c7157.gz'
> using driver `GML' successful.
> 1: Road (None)
> 2: RoadLink (Line String)
> 3: RoadNode (Point)
> $ ogrinfo raw_itn/6360199_sn6101_2c5532.__gz
> INFO: Open of `raw_itn/6360199_sn6101___2c5532.gz'
> 1: RoadLinkInformation (Point)
> 2: Road (None)
> 3: RoadLink (Line String)
> 4: RoadNodeInformation (None)
> 5: RoadNode (Point)
> Here is want I am trying:
> dropdb -U postgres -h localhost data_itn
> createdb -U postgres -h localhost data_itn
> psql -U postgres -h localhost data_itn -c "create extension
> postgis"
> psql -U postgres -h localhost data_itn -c "create schema itn"
> psql -U postgres -h localhost data_itn -c "alter database
> data_itn set
> search_path to itn, public, pg_catalog"
> # this loads fine
> ogr2ogr -append -f PostgreSQL PG:"host=localhost user=postgres
> dbname=data_itn" raw_itn/6360199_sn6101_2c5532.__gz
> # all successive tries to append to the existing tables fails
> ERROR 1: Layer road already exists, CreateLayer failed.
> Use the layer creation option OVERWRITE=YES to replace it.
> ERROR 1: Terminating translation prematurely after failed
> translation of layer Road (use -skipfailures to skip errors)
> If I don't install extension postgis then there is no
> problem reported
> and it appears to load all the data by appending the tables
> with the
> geometry in a colum wkb_geometry::bytea.
> How can I load the data into postgis. I have over 700 gml
> files to load.
> Defining PG_LIST_ALL_TABLES=YES as environment variable should
> solve this. By
> default non-spatial tables are not listed when opening a PG
> database, and
> ogr2ogr is confused as it doesn't see the existing table as
> existing, so it
> tries to recreate it. With trunk, ogr2ogr & the PG driver have
> been improved
> so that specifying PG_LIST_ALL_TABLES=YES is not needed in that
> scenario.
> Wondering if we shouldn't list all tables (excluding system
> tables) by
> default...
> Thank you this is a very helpful response. I saw the
> PG_LIST_ALL_TABLES=YES in the documentation, but but never connect
> that with this problem.
> If there is not a huge downside to listing all tables I can't see
> that it is a problem because it only happens once after a
> connection. Or maybe it only needs to be done if -append is set.
> Anyway, Thanks for the help with this.
> -Steve
> Thanks,
> -Steve
> This email has been checked for viruses by Avast antivirus
> software.
> http://www.avast.com
> _________________________________________________
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
> http://lists.osgeo.org/__mailman/listinfo/gdal-dev
> <http://lists.osgeo.org/mailman/listinfo/gdal-dev>
> This email has been checked for viruses by Avast antivirus software.
