[gdal-dev] GDAL overrite file error
Even Rouault
even.rouault at spatialys.com
Thu May 7 13:15:27 PDT 2015
Le jeudi 07 mai 2015 21:53:19, Stefan Keller a écrit :
> Hi Even (and Peter)
> Thanks for your quick answers! I actually referred to file related
> read/write formats.
> I tested some of them, if they support overwriting (I think this is
> not always documented in the docs).
> I fact, following support the -overwrite option (in alphabetical
> order): GPKG, Mapinfo File, ESRI Shapefil, SQLite
> Following don't: CSV, DXF, GeoJSON, GeoRSS, GML, GPX, Interlis 2, KML,
> PDF and
Yes expected, none of them support DeleteLayer()
> Spatialite (as SQLite w/ -dsco SPATIALITE=yes)
Strange : could you provide a reproducable way for this ?
The following works for me :
rm poly.sqlite
ogr2ogr -f sqlite poly.sqlite poly.shp -dsco spatialite=yes
ogr2ogr poly.sqlite poly.shp -overwrite
> Cheers, Stefan
> P.S. Interlis 1 crashes currently :-< Pirmin is working on it and I
> hope his patch will make it int the next release before code freeze.
OK, there's no ticket for that ?
> 2015-05-07 20:56 GMT+02:00 Even Rouault <even.rouault at spatialys.com>:
> > Le jeudi 07 mai 2015 20:27:03, Stefan Keller a écrit :
> >> Hi,
> >> Regarding overwrite:
> >> I think the "-overwrite" parameter in ogr2ogr commandline tool does not
> >> work. I tried it with drivers like "ESRI Shapefile", GeoJSON and others
> >> without success.
> >> ogr2ogr always exits and reports
> >> "ERROR 6: The GeoJSON driver does not overwrite existing files."
> >> Why should drivers not be able to overwrite?
> > -overwrite causes an existing layer to be deleted before being recreated,
> > for drivers that support the DeleteLayer() API.
> > It does not cause an existing dataset to be destroyed however (which
> > would be calling DeleteDataSource(), which isn't implemented by all
> > drivers either), which is the issue you must have with the geojson
> > driver.
> > For shapefiles, that works in my testing however.
> > I know this is a bit user unfriendly: nothing fundamentally impossible to
> > improve here, just historic behaviour.
> >> Is'nt deleting files common task for all drivers (meaning to be
> >> handled outside the actual writer drivers)?
> > Implementation of DeleteLayer() is driver specific code, since only
> > drivers know which files (when files are involve. Think to a PostGIS
> > table) are related to a layer.
> >> -S.
> >> 2015-02-06 11:06 GMT+01:00 Even Rouault <even.rouault at spatialys.com>:
> >> > Le vendredi 06 février 2015 10:42:04, Carlos Piury a écrit :
> >> >> Hi, I am trying to create a vector format (i.e. ESRI Shapefile) from
> >> >> laser file (.las), and it works fine, but when I try to overwrite the
> >> >> file I get the following error:
> >> >> ERROR 1: Layer 'output' already exists
> >> > --> The message is hopefully clear enough and comes from the
> >> > implementation of CreateLayer() in the shape file driver. You have to
> >> > destroy the files of the shapefile first if they exists. You can use
> >> > DeleteDataSource() for that.
> >> >> terminate called after throwing an instance of 'std::runtime_error'
> >> >> what(): output layer creation failed
> >> >> Aborted (core dumped)
> >> > Does this come from inside GDAL code or you own code ? Looks like from
> >> > yours, if you transform GDAL errors into C++ exceptions.
> >> >> I am using the next code to create the layer:
> >> >> OGRSFDriverH formatTranslateDriver =
> >> >> OGRGetDriverByName(argFormat->sval[0]);
> >> >> OGRDataSourceH dataset =
> >> >> OGR_Dr_CreateDataSource(formatTranslateDriver, argOutput->sval[0],
> >> >> 0);
> >> >> OGRLayerH layer = OGR_DS_CreateLayer(dataset, layerName.c_str(), 0,
> >> >> wkbPoint25D, 0);
> >> >> Any idea about this error?
> >> >> Thanks.
> >> > Spatialys - Geospatial professional services
> >> > http://www.spatialys.com
> >> > _______________________________________________
> >> > gdal-dev mailing list
> >> > gdal-dev at lists.osgeo.org
> >> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
