[gdal-dev] GDAL overrite file error
Stefan Keller
sfkeller at gmail.com
Thu May 7 13:34:55 PDT 2015
2015-05-07 22:15 GMT+02:00 Even Rouault <even.rouault at spatialys.com>:
>> Spatialite (as SQLite w/ -dsco SPATIALITE=yes)
> Strange : could you provide a reproducable way for this ?
> The following works for me :
> rm poly.sqlite
> ogr2ogr -f sqlite poly.sqlite poly.shp -dsco spatialite=yes
> ogr2ogr poly.sqlite poly.shp -overwrite
You're right again.
I repeated (unnecessarily) the dataset creation (-dsco) option in the
second statement with overwrite:
rm poly.sqlite
ogr2ogr poly.sqlite poly.shp -overwrite -dsco spatialite=yes
-S.
> Le jeudi 07 mai 2015 21:53:19, Stefan Keller a écrit :
>> Hi Even (and Peter)
>> Thanks for your quick answers! I actually referred to file related
>> read/write formats.
>> I tested some of them, if they support overwriting (I think this is
>> not always documented in the docs).
>> I fact, following support the -overwrite option (in alphabetical
>> order): GPKG, Mapinfo File, ESRI Shapefil, SQLite
>> Following don't: CSV, DXF, GeoJSON, GeoRSS, GML, GPX, Interlis 2, KML,
>> PDF and
> Yes expected, none of them support DeleteLayer()
> rm poly.sqlite
>> Cheers, Stefan
>> P.S. Interlis 1 crashes currently :-< Pirmin is working on it and I
>> hope his patch will make it int the next release before code freeze.
> OK, there's no ticket for that ?
>> 2015-05-07 20:56 GMT+02:00 Even Rouault <even.rouault at spatialys.com>:
>> > Le jeudi 07 mai 2015 20:27:03, Stefan Keller a écrit :
>> >> Hi,
>> >> Regarding overwrite:
>> >> I think the "-overwrite" parameter in ogr2ogr commandline tool does not
>> >> work. I tried it with drivers like "ESRI Shapefile", GeoJSON and others
>> >> without success.
>> >> ogr2ogr always exits and reports
>> >> "ERROR 6: The GeoJSON driver does not overwrite existing files."
>> >> Why should drivers not be able to overwrite?
>> > -overwrite causes an existing layer to be deleted before being recreated,
>> > for drivers that support the DeleteLayer() API.
>> > It does not cause an existing dataset to be destroyed however (which
>> > would be calling DeleteDataSource(), which isn't implemented by all
>> > drivers either), which is the issue you must have with the geojson
>> > driver.
>> > For shapefiles, that works in my testing however.
>> > I know this is a bit user unfriendly: nothing fundamentally impossible to
>> > improve here, just historic behaviour.
>> >> Is'nt deleting files common task for all drivers (meaning to be
>> >> handled outside the actual writer drivers)?
>> > Implementation of DeleteLayer() is driver specific code, since only
>> > drivers know which files (when files are involve. Think to a PostGIS
>> > table) are related to a layer.
>> >> -S.
>> >> 2015-02-06 11:06 GMT+01:00 Even Rouault <even.rouault at spatialys.com>:
>> >> > Le vendredi 06 février 2015 10:42:04, Carlos Piury a écrit :
>> >> >> Hi, I am trying to create a vector format (i.e. ESRI Shapefile) from
>> >> >> laser file (.las), and it works fine, but when I try to overwrite the
>> >> >> file I get the following error:
>> >> >> ERROR 1: Layer 'output' already exists
>> >> > --> The message is hopefully clear enough and comes from the
>> >> > implementation of CreateLayer() in the shape file driver. You have to
>> >> > destroy the files of the shapefile first if they exists. You can use
>> >> > DeleteDataSource() for that.
>> >> >> terminate called after throwing an instance of 'std::runtime_error'
>> >> >> what(): output layer creation failed
>> >> >> Aborted (core dumped)
>> >> > Does this come from inside GDAL code or you own code ? Looks like from
>> >> > yours, if you transform GDAL errors into C++ exceptions.
>> >> >> I am using the next code to create the layer:
>> >> >> OGRSFDriverH formatTranslateDriver =
>> >> >> OGRGetDriverByName(argFormat->sval[0]);
>> >> >> OGRDataSourceH dataset =
>> >> >> OGR_Dr_CreateDataSource(formatTranslateDriver, argOutput->sval[0],
>> >> >> 0);
>> >> >> OGRLayerH layer = OGR_DS_CreateLayer(dataset, layerName.c_str(), 0,
>> >> >> wkbPoint25D, 0);
>> >> >> Any idea about this error?
>> >> >> Thanks.
>> >> > Spatialys - Geospatial professional services
>> >> > http://www.spatialys.com
>> >> > _______________________________________________
>> >> > gdal-dev mailing list
>> >> > gdal-dev at lists.osgeo.org
>> >> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
