[gdal-dev] JP2 GML Axis Order Problem
Dennis Gocke
dengo at gmx.net
Wed May 13 06:13:21 PDT 2015
Hi Even,
I've created ticket #5960 <http://trac.osgeo.org/gdal/ticket/5960>
Best Regards,
Dennis
On Wed, May 13, 2015 at 2:58 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Dennis,
> Could you open a ticket in GDAL Trac about that ?
> Even
> > Hi guys,
> > we have a Pleiades image here, the jp2 coming directly from the provider
> > with an GML header like this:
> > <gml:featureMember>
> > <gml:FeatureCollection>
> > <gml:featureMember>
> > <gml:RectifiedGridCoverage dimension="2"
> > gml:id="COVERAGE_DS_PHR1A_201306090940372_FR1_PX_E017N43_0315_01434">
> > <gml:description>Ortho
> > coverage</gml:description>
> > <gml:name>DS_PHR1A_201306090940372_FR1_PX_E017N43_0315_01434</gml:name>
> > <gml:rectifiedGridDomain>
> > <gml:RectifiedGrid dimension="2">
> > <gml:limits>
> > <!-- The PLEIADES convention is used: first pixel on the product
> > is pixel (1,1) -->
> > <gml:GridEnvelope>
> > <gml:low>1 1</gml:low>
> > <gml:high>8528 7086</gml:high>
> > </gml:GridEnvelope>
> > </gml:limits>
> > <!--first axis easting: urn:ogc:def:axis-name:EPSG::3035-->
> > <gml:axisName>Easting</gml:axisName>
> > <!--second axis northing: urn:ogc:def:axis-name:EPSG::3035-->
> > <gml:axisName>Northing</gml:axisName>
> > <gml:origin>
> > <gml:Point srsName="urn:ogc:def:crs:EPSG::3035">
> > <gml:pos>4895767.000000000000000
> > 2296945.000000000000000</gml:pos>
> > </gml:Point>
> > </gml:origin>
> > <gml:offsetVector
> > srsName="urn:ogc:def:crs:EPSG::3035">2.000000000000000
> 0</gml:offsetVector>
> > <gml:offsetVector srsName="urn:ogc:def:crs:EPSG::3035">0
> > -2.000000000000000</gml:offsetVector>
> > </gml:RectifiedGrid>
> > </gml:rectifiedGridDomain>
> > <gml:rangeSet>
> > <gml:File>
> > <gml:rangeParameters>
> > <gml:QuantityExtent uom="int">0 255</gml:QuantityExtent>
> > </gml:rangeParameters>
> > <gml:fileName>gmljp2://codestream/0</gml:fileName>
> > <gml:fileStructure>Record Interleaved</gml:fileStructure>
> > </gml:File>
> > </gml:rangeSet>
> > </gml:RectifiedGridCoverage>
> > </gml:featureMember>
> > </gml:FeatureCollection>
> > The LAEA projection (EPSG::3035) is defined with having an axis order of
> Y,
> > X, which means GDAL swaps the axis of the geotransform. But in this case
> > this gives the wrong result. The JP2 GML defines an X,Y axis order by
> > putting in <gml:axisName> tags, which are not yet considered by GDAL,
> > neither GDAL 1.11 nor GDAL 2.0.0 beta1.
> > We can solve this issue by setting the GDAL_IGNORE_AXIS_ORIENTATION to
> > true, but maybe it would be better if GDAL would consider the
> > <gml:axisName>
> > Best Regards,
> > Dennis
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150513/16d7ee59/attachment.html>
