[gdal-dev] ogr2ogr segfault
Even Rouault
even.rouault at spatialys.com
Tue May 19 03:25:53 PDT 2015
Le mardi 19 mai 2015 12:21:15, Ari Jolma a écrit :
> >>>> Hi all.
> >>>> I'm consistently getting a segfault from:
> >>>> ogr2ogr OUTPUTLAYER.shp strade.shp strade -dialect sqlite -sql "SELECT
> >>>> ST_Line_Interpolate_Point( geometry , 0.5 ),* FROM 'strade' "
> >>>> Anything I can do for debugging?
> >>> Running under gdb and displaying the stack trace.
> >> ogr2ogr OUTPUTLAYER.shp strade.shp -dialect sqlite -sql "SELECT
> >> ST_Line_Interpolate_Point( geometry , 0.5 ),* FROM 'strade'"
> >> ERROR 1: In ExecuteSQL(): sqlite3_prepare(SELECT
> >> ST_Line_Interpolate_Point( geometry , 0.5 ),* FROM 'strade'):
> >> no such function: ST_Line_Interpolate_Point
> >> I have both SQLite and SpatiaLite support on. What's going on?
> > Not using a recent enough SpatiaLite I guess
> I've now got the latest SpatiaLite version but ogr2ogr is still
> complaining.
Check with
ogrinfo strade.shp -dialect sqlite -sql "select spatialite_version()"
that you're linking against the spatialite version you expect.
> However, I got also the SpatiaLite CLI and it has no problems:
> spatialite> .loadshp strade strade utf8
> Loading shapefile at 'strade' into SQLite table 'strade'
> BEGIN;
> CREATE TABLE "strade" (
> "PK_UID" INTEGER PRIMARY KEY AUTOINCREMENT,
> "id" INTEGER);
> SELECT AddGeometryColumn('strade', 'Geometry', -1, 'LINESTRING', 'XY');
> COMMIT;
> Inserted 1 rows into 'strade' from SHAPEFILE
> spatialite> SELECT astext(ST_Line_Interpolate_Point( geometry , 0.5 )),*
> FROM 'strade';
> POINT(-0.352046 0.4463)|1|0|
> Hm.
> Ari
http://www.spatialys.com
