[gdal-dev] JP2OpenJPEG Driver Reads 4th Band of NITF as Alpha
Claire Porter
claire.porter at gmail.com
Tue May 19 15:54:19 PDT 2015
Hello,
I use the OpenJPEG 2.0 driver to decode the JP2 images within NITF files
(1B level NITF images from DigitalGlobe). For 4 band images, the driver
interprets the 4th band as Alpha. When I warp the imagery using gdalwarp,
the 4th band in the output is all zeros. If I convert the image using
gdal_translate, the 11 bit values in the 4th band are truncated to 255.
Using GTiff creation options of PHOTOMETRIC=RGB or MINISBLACK and ALPHA=NO
do not change the results.
I found this only occurs with the OpenJPEG driver. The Jasper, Kakadu, and
ECW drivers interpret the 4th band as Undefined and the 4th band behaves
normally in gdalwarp and gdal_translate. I've tried gdal versions from
1.9.0 to 1.11.1. I thought perhaps the issue would be solved in OpenJPEG
2.1, and so I tried compiling GDAL 1.11.1 with OpenJPEG 2.1.0. But, that
still resulted in the 4th band being read as Alpha.
I'd really like to continue using OpenJPEG since it will be so well
supported in GDAL 2.0. Anyone know a work around for this? Is this a GDAL
issue or an OpenJPEG issue?
Thanks,
Claire
*gdalinfo using the OpenJPEG driver and GDAL 1.11.1:*
OPENJPEG: info: Start to read j2k main header (0).
OPENJPEG: info: Main header has been correctly decoded.
GDAL:
GDALOpen(/vsisubfile/3935_198497332,output/WV02_12OCT082110317-M1BS-103001001B68B600.ntf,
this=0x948760) succeeds as JP2OpenJPEG.
GDAL: NITFDataset::Open() wasn't able to derive a first order
geotransform. It will be returned as GCPs.
GDAL: GDALDefaultOverviews::OverviewScan()
GDAL: GDALOpen(output/WV02_12OCT082110317-M1BS-103001001B68B600.ntf,
this=0x8bfd10) succeeds as NITF.
Driver: NITF/National Imagery Transmission Format
Files: output/WV02_12OCT082110317-M1BS-103001001B68B600.ntf
output/WV02_12OCT082110317-M1BS-103001001B68B600.xml
Size is 9216, 8192
Coordinate System is `'
GCP Projection =
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
SAMP_OFF=4409
SAMP_SCALE=4410
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 8192.0)
Upper Right ( 9216.0, 0.0)
Lower Right ( 9216.0, 8192.0)
Center ( 4608.0, 4096.0)
Band 1 Block=1024x1024 Type=UInt16, ColorInterp=Blue
Overviews: 4608x4096, 2304x2048, 1152x1024, 576x512, 288x256
Overviews: arbitrary
Image Structure Metadata:
NBITS=11
Band 2 Block=1024x1024 Type=UInt16, ColorInterp=Green
NBITS=11
Band 3 Block=1024x1024 Type=UInt16, ColorInterp=Red
NBITS=11
Band 4 Block=1024x1024 Type=UInt16, ColorInterp=*Alpha*
NBITS=11
GDAL:
GDALClose(/vsisubfile/3935_198497332,output/WV02_12OCT082110317-M1BS-103001001B68B600.ntf,
this=0x94d3f0)
GDAL:
this=0x948760)
GDAL: GDALClose(output/WV02_12OCT082110317-M1BS-103001001B68B600.ntf,
this=0x8bfd10)
*gdalinfo using** ECW and 1.11.1 (Jasper and Kakadu are similar):*
ECW:
NCScbmOpenFileView(/vsisubfile/3935_198497332,Z:\claire\debug_ortho\output2\WV02_12OCT082110317-M1BS-103001001B68B600.ntf):
eErr=2, will try VSIL stream.
ECW: Got mutex.
ECW: Using filename 'C:\Users\porte254\AppData\Local\Temp\99544_0.ntf' for
temporary directory determination purposes.
ECW: Using filename 'C:\Users\porte254\AppData\Local\Temp\99544_1.ntf' for
ECW: Using filename 'C:\Users\porte254\AppData\Local\Temp\99544_2.ntf' for
ECW: Using filename 'C:\Users\porte254\AppData\Local\Temp\99544_3.ntf' for
ECW: Using filename 'C:\Users\porte254\AppData\Local\Temp\99544_4.ntf' for
ECW: Using filename 'C:\Users\porte254\AppData\Local\Temp\99544_5.ntf' for
ECW: Using filename 'C:\Users\porte254\AppData\Local\Temp\99544_6.ntf' for
ECW: Using filename 'C:\Users\porte254\AppData\Local\Temp\99544_7.ntf' for
ECW: Using filename 'C:\Users\porte254\AppData\Local\Temp\99544_8.ntf' for
ECW: FileInfo: SizeXY=9216,8192 Bands=4
OriginXY=0,0 CellIncrementXY=1,1
ColorSpace=3, eCellType=1
GDAL:
GDALOpen(/vsisubfile/3935_198497332,Z:\claire\debug_ortho\output2\WV02_12OCT082110317-M1BS-103001001B68B600.ntf,
this=000000000032FBA0) succeeds as JP2ECW.
GDAL:
GDALOpen(Z:\claire\debug_ortho\output2\WV02_12OCT082110317-M1BS-103001001B68B600.ntf,
this=000000000031EC40) succeeds as NITF.
Files: output2\WV02_12OCT082110317-M1BS-103001001B68B600.ntf
output2\WV02_12OCT082110317-M1BS-103001001B68B600.XML
Size is 9216, 8192
GCP Projection =
GEOGCS["WGS 84",
DATUM["WGS_1984",
SAMP_OFF=4409
SAMP_SCALE=4410
Corner Coordinates:
Band 1 Block=256x256 Type=UInt16, ColorInterp=Blue
NBITS=11
Band 2 Block=256x256 Type=UInt16, ColorInterp=Green
NBITS=11
Band 3 Block=256x256 Type=UInt16, ColorInterp=Red
NBITS=11
Band 4 Block=256x256 Type=UInt16, ColorInterp=*Undefined*
NBITS=11
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150519/40485ce7/attachment.html>
