[gdal-dev] CSharp bindings question
Ari Jolma
ari.jolma at gmail.com
Fri May 29 06:15:35 PDT 2015
On 29.05.2015 15:22, Tamas Szekeres wrote:
> Hi Ari,
> Which SWIG version have you been testing with?
Mostly with the one that's loaded by default into a new Ubuntu (travis)
/ Mint (I have version 17 which is based on Ubuntu Trusty), both are
2.0.11 I think.
> Converting IntPtr to string doesn't seem to be a good solution. We
> should do something like what we do for ReadRaster which also use
> AddrOfPinnedObject(). I'm trying to reproduce this.
Yes I'm sure it is not, I just used it to make it compile. It is used
only(?) by FileFromMemBuffer, which is not tested in CSharp tests (I'm
not yet testing it in Perl bindings either).
Ari
> Best regards,
> Tamas
> 2015-05-29 9:11 GMT+02:00 Ari Jolma <ari.jolma at gmail.com
> <mailto:ari.jolma at gmail.com>>:
> In my fork I've now added mono-mcs into the travis test machine
> and "make test" to CSharp. The build & tests all work.
> https://travis-ci.org/OSGeo/gdal/builds/64450000
> However, one fix I did for the CSharp bindings is most probably
> wrong (convert return value of handle.AddrOfPinnedObject() to char *)
> https://github.com/ajolma/gdal/commit/6509ef06d6f89d99c446300e4f4a63b65613911e
> Tamas, do you have an idea for this?
> There are a lot of #if ... #endif's in for example ogr.i to limit
> %feature("kwargs"), this is due to a swig bug, which is fixed in
> 3.03 so we need to leave them in for now.
> https://github.com/swig/swig/issues/242
> There's a lot still to do to cleanup the common interface files
> but how do you feel, is there a chance that this is accepted into
> the trunk (and 2.1)? I'd also love to have a policy for developing
> the bindings and working test codes for all maintained languages.
> A rule could be that the use of #if ... #endif in common files
> needs a good justification and commits, which do not cause test
> codes to fail are ok per se.
> Best,
> Ari
> On 26.05.2015 13:53, Tamas Szekeres wrote:
>> Is that a requirement that the bindings should work well with all
>> SWIG versions or that the generated wrappers should work just fine?
>> Formerly I have been thinking that we should support all
>> versions, but it took large amount of extra efforts to work
>> around all incompatible changes what SWIG introduces all the time
>> even with the minor releases. Regarding to SWIG C# the earlier
>> versions produced definitely wrong code and I had implement quite
>> some generic stuff in the bindings (for example to work around
>> the early garbage collection issues). I see some enhancements in
>> the recent versions in this regard, but I'm not sure if I can
>> completely remove these additions to get a stable and consistent
>> build.
>> Tamas
>> 2015-05-26 11:09 GMT+02:00 Ari Jolma <ari.jolma at gmail.com
>> 26.05.2015, 11:38, Even Rouault kirjoitti:
>> Le mardi 26 mai 2015 10:13:49, Tamas Szekeres a écrit :
>> Hi Ari,
>> I haven't tried to compile that with mono for quite a
>> long time. I'll give
>> it a try.
>> However we did not follow the latest changes in the
>> SWIG implementation
>> with the bindings, so I'd try with an earlier version
>> (ie. 1.3.39) to
>> generate the wrappers.
>> I can confirm that I can compile the CSharp bindings on
>> Linux with SWIG 1.3.40
>> (and run the tests), but I get the same error as Ari with
>> SWIG 2.0.X
>> As far as I know, Java and Python bindings build and run
>> equaly well with SWIG
>> 1.3.40 or 2.0.X (although there's a Unix makefile hack to
>> have Python 3.2
>> compat, conditionnaly applied with SWIG 1.3.40, that is
>> no longer needed with
>> SWIG 2.0.4 or later)
>> Swig 1.3.39 seems questionable. Just look at the download
>> amounts at sourceforge. 1.3.39 one download and 1.3.40 148
>> downloads per week.
>> However, 1.3.39 does *not* put the PVINVOKE() method twice
>> into the PVINVOKE.cs file.
>> May be we should consider including the generated
>> wrappers in gdal instead of let the users to use
>> different versions with
>> different results.
>> It would be good if we could have a common SWIG version
>> that works for all the
>> bindings. So currently it seems to be 1.3.40 ?
>> Regarding putting the generated wrappers in SVN, that's
>> already what we do for
>> Python. We could also just include the generated wrappers
>> in the tarballs.
>> IMO "users" = people who use ready-made packages. Developers
>> and packagers should be intelligent enough to use development
>> tools. I don't like the idea of having generated files in
>> source repositories. I'm also of the opinion that there
>> should be a really good reason to use an old version of a
>> common tool. And at least in my Linux (Mint, Maya - hmm, that
>> seems already pretty old, I should upgrade) swig 2.0.11 is
>> the current. But that's just me I guess.
>> Ari
>> Even
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150529/d1b26e8a/attachment.html>
