[gdal-dev] VSI handlers as plugin (shared library)
Ivan Lucena lucena_ivan at hotmail.com
Mon Nov 2 11:58:59 PST 2015
Hi there,
What if we could build and distribute VSI handler as plugins?
I developed a VSI handler that depends on other software, so I would rather not build the GDAL main library with that dependency and let the user decided if they want to use the plugin or not.
We would need to have a code on cpl_vsil.cpp similar to AutoLoadDrivers() from  gdaldrivermanager.cpp to load vsi_XXX.{so,dll} dynamically.
Would that be worth the effort? Any other cases where that could be useful?
Regards.
Ivan
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20151102/1105612c/attachment.html>
