[gdal-dev] Promote debug msg to warning
Even Rouault even.rouault at spatialys.com
Tue Nov 3 09:36:24 PST 2015
Le mardi 03 novembre 2015 09:07:29, Paul Meems a écrit :
> Hi all,
> We use GDAL with MapWindow GIS and get the binaries from gisinternals.com.
> We have a SpatiaLite file which can be opened by MapWindow (via GDAL) but
> cannot be edited.
> We had to enable the debug messages to understand why.
> GDAL reports "SpatiaLite v4 DB found, but updating tables disabled because
> runtime spatialite library is v3.0 !" which is a understandable message but
> because it is a debug message and not a warning message it is hard to spot.
> Wouldn't it be more logical if GDAL would report this message as a warning?
I guess that would make sense, but only if the database is opened in update
mode (I've not verified if the message is only emitted in that case), and in
that case return NULL. Patch welcome.
> Thanks,
> Paul
> *Paul Meems *
> Release manager, configuration manager
> and forum moderator of MapWindow GIS.
> www.mapwindow.org
> Owner of MapWindow.nl - Support for
> Dutch speaking users.
> www.mapwindow.nl
> *We've started with the development of MapWindow v5. Read more.
> <http://www.mapwindow.org/documentation/mapwingis4.9/MapWindow49.html>*
http://www.spatialys.com
