[gdal-dev] Trying to debug a GDAL crash in "GDALClose(hDataset); "
Joaquim Luis
jluis at ualg.pt
Sat Nov 14 11:57:35 PST 2015
My bad, I don't know how to produce a stack trace from within the VS
debugger. I have it all visually but find no option to save it as a file.
I added a breakpoint at cpl_atomic_ops.cpp#L56 but it didn't stop there
after the call to GDALClose(hDataset);
Actually when stepping in it jumps directly from GDALClose() into
CPLAtomicCompareAndExchange() but once there (due to crash) I can step
back to other functions.
Sorry if it's not clear.
Do you have a GMT build with GDAL svn? Could you please try if this
crashes for you
grdmath -Rd -I1 X = lixo.tiff:GTiff
grdinfo -R0/20/30/50 lixo.tiff
> nLockCount should be set by
> https://trac.osgeo.org/gdal/browser/trunk/gdal/gcore/gdal_priv.h#L598
> https://trac.osgeo.org/gdal/browser/trunk/gdal/port/cpl_atomic_ops.cpp#L56
> which uses InterlockedCompareExchange to change it.
> Can you give the whole stack trace?
> On Fri, Nov 13, 2015 at 6:47 PM, Joaquim Luis <jluis at ualg.pt> wrote:
>> Hi,
>> I'm having strange crashes in GDAL (SVN) when called via GMT. The
>> crashes occur at a call to
>> Now, this is only occurs when I try to read a sub-region of a grid but
>> those are GMT details.
>> It doesn't happen to colleagues on OSX but they are using gdal 1.11.
>> Can't say that's the reason but this used to work for me as well on
>> Windows (I >>should know because I wrote that code).
>> I built a GDAL debug and can see that the crash happens in
>> cpl_atomic_ops.cpp
>> int CPLAtomicCompareAndExchange(volatile int* ptr, int oldval, int
>> newval)
>> return (LONG)InterlockedCompareExchange((volatile LONG*)(ptr),
>> (LONG)newval, (LONG)oldval) == (LONG)oldval;
>> because the 'ptr' is invalid. That function is called by
>> gdalrasterblock.cpp
>> GDALRasterBlock::DropLockForRemovalFromStorage()
>> if( CPLAtomicCompareAndExchange(&nLockCount, 0, -1) )
>> and the debugger tells me that
>> nLockCount <Unable to read memory>
>> and here I'm lost. Where is nLockCount supposed to be set?
>> Thanks
>> Joaquim
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20151114/1d084c5c/attachment.html>
