[gdal-dev] GCPsToGeoTransform returns wrong values
Ari Jolma
ari.jolma at gmail.com
Wed Nov 18 02:13:15 PST 2015
On 18.11.2015 11:59, Bar Ori wrote:
> Thanks Ari for your reply.
> In my situation, sometimes I am working with rectangles and sometimes
> not. Depends the source of information.
> I thought to always use the GCPs as follows:
> In case my shape has rectangular form, so the dataSet.GetGCPCount()
> will return me “0” and I will use the dataSet.GetGeoTransform(),
> otherwise, will use the dataSet.GetGCPs().
> The issue is that for setting the GCPs, I must put the coordinate in
> the middle of pixel (that is why I subtract “0.5”). If I wouldn’t, so
> yes, the geotransform values would be correct.
> Is it a bad practice? Should I figure out the shape from start and to
> take two different steps?
I don't know the best answer to that. I'm just assuming if you do it
with some GUI tool for example it will report you pixel coordinates in
integer values.
Ari
> *From:*gdal-dev [mailto:gdal-dev-bounces at lists.osgeo.org] *On Behalf
> Of *Ari Jolma
> *Sent:* 18 November 2015 11:35
> *To:* gdal-dev at lists.osgeo.org
> *Subject:* Re: [gdal-dev] GCPsToGeoTransform returns wrong values
> Bar,
> I think you are setting the GCPs up wrongly if you want them to be at
> the corners.
> GCP(LeftDown.X, LeftDown.Y, LeftDown.Z, Height - 0.5, null, "4") does
> not have 0 before Height-0.5.
> GCPsToGeoTransform checks the special case of GCPs in rectangular
> shape and in top-left, top-right, bottom-right, bottom-left order and
> returns the exact transform the dataset has.
> I'm not sure if it makes sense to have real values for the pixel
> coordinates although they are real values.
> Best,
> Ari
> On 18.11.2015 09:32, Bar Ori wrote:
> Hi,
> I noticed something that for me looks weird and I would like to
> know maybe I am doing something wrong.
> If not, how should I overcome this behavior.
> I set 4 GCPs as follows:
> vargcps = new[]
> newGCP(LeftUp.X, LeftUp.Y, LeftUp.Z, 0.5, 0.5, null, "1"),
> newGCP(RightUp.X, RightUp.Y, RightUp.Z, Width - 0.5, 0.5, null, "2"),
> newGCP(RightDown.X, RightDown.Y, RightDown.Z, Width - 0.5, Height
> - 0.5, null, "3"),
> newGCP(LeftDown.X, LeftDown.Y, LeftDown.Z, Height - 0.5, null, "4")
> And when I am doing as follows:
> vargeotransform = newdouble[6];
> Gdal.GCPsToGeoTransform(gcps, geotransform, 0)
> Or (after using dataSet.SetGCPs(gcps, projection) :
> dataSet.GetGeoTransform(geotransform);
> So the values returned, are wrong.
> For example, if the LeftUp.X was 35.01050 so the value of
> geotransform[0], which supposed to be the same value, can be 35.0082.
> The same with all the geotransform values.
> If I am getting from the dataset and setting again, every time it
> is changing more and more.
> Is there any connection to the use of the “0.5”?
> Thanks.
> *Ori Bar |***Software Developer
> Applications Development
> Elbit Systems Land and C4I
> *T *+972-9-8898*900 **|****M***+972-504-734296
> *The information in this e-mail transmission contains proprietary
> and business **
> *sensitive information. Unauthorized interception of this e-mail
> may constitute *
> *a violation of law. If you are not the intended recipient, you
> are hereby *
> *notified that any review, dissemination, distribution or
> duplication of this *
> *communication is strictly prohibited. You are also asked to
> contact the sender *
> *by reply email and immediately destroy all copies of the original
> message.**
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
> *The information in this e-mail transmission contains proprietary and
> business
> sensitive information. Unauthorized interception of this e-mail may
> constitute
> a violation of law. If you are not the intended recipient, you are hereby
> notified that any review, dissemination, distribution or duplication
> of this
> communication is strictly prohibited. You are also asked to contact
> the sender
> by reply email and immediately destroy all copies of the original message.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20151118/94f1a5f1/attachment-0001.html>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20151118/94f1a5f1/attachment-0001.png>
