[gdal-dev] GeoTransform confusion
Simon Lyngby Kokkendorff silyko at gmail.com
Thu Nov 19 01:15:15 PST 2015
Thanks Ari,
   I wasn't aware of that. Naively assumed that GDAL would just keep the
geotransform in a gdal_translate, no matter what. Good to know, thanks!
Cheers,
SImon
On Thu, Nov 19, 2015 at 10:03 AM, Ari Jolma <ari.jolma at gmail.com> wrote:
> Simon,
> If you set the configuration option GTIFF_POINT_GEO_IGNORE to "TRUE"
> instead of the default "FALSE" the offset will not happen.
> I've tested this and it works. The configuration option needs to be set in
> code, it is not a GTiff creation option.
> I'm not quite sure why you need to do that. Anyway it happens when the
> destination geotiff is created and its fields are set. The
> geotransformation of the geotiff file are set indirectly using geotiepoints
> using the geotransformation of the source (which is correct).
> Ari
> On 19.11.2015 10:24, Simon Lyngby Kokkendorff wrote:
> Basically it seems to be an issue with interpreting "center" directives
> when doing the gdal_translate. Consider:
> ncols 2
> nrows 2
> xllcenter 0.0
> yllcenter 0.0
> cellsize 1.0
> nodata_value -999
> 2 2
> 2 2
> gdalinfo on this file, will give the expected GeoTransform:
> In [2]: ds = gdal.Open("center.asc")
> In [3]: ds.GetGeoTransform()
> Out[3]: (-0.5, 1.0, 0.0, 1.5, 0.0, -1.0)
> Seems OK to me.
> If I then do a gdal_translate: gdal_translate center.asc center.tif, I get
> another interpretation:
> In [4]: ds = gdal.Open("center.tif")
> In [5]: ds.GetGeoTransform()
> Out[5]: (0.0, 1.0, 0.0, 1.0, 0.0, -1.0)
> And, if I do a roundtrip: gdal_translate -of AAIGRID center.tif
> center_back.asc, I get:
> ncols        2
> nrows        2
> xllcorner    0.000000000000
> yllcorner    -1.000000000000
> cellsize     1.000000000000
> NODATA_value -999
>  2 2
>  2 2
> Which is definitely not the same GeoTransform as my input center.asc, but
> shifted half a cellsize from what I would expect...
> In [6]: ds = gdal.Open("center_back.asc")
> In [7]: ds.GetGeoTransform()
> Out[7]: (0.0, 1.0, 0.0, 1.0, 0.0, -1.0)
> GDAL version:
> GDAL 1.11.2, released 2015/02/10
> Cheers,
> Simon
> On Wed, Nov 18, 2015 at 9:38 PM, Simon Lyngby Kokkendorff <
> <silyko at gmail.com>silyko at gmail.com> wrote:
>> Hi List,
>>   I have a geoid in AAIGRID-format, with the following header:
>> ncols 1001
>> nrows 731
>> xllcenter 400000.0
>> yllcenter 6045000.0
>> cellsize 500.0
>> NODATA_value 9999
>> GDAL will read this just fine, and report:
>> Driver: AAIGrid/Arc/Info ASCII Grid
>> Files: dkgeoid13b.utm32
>> Size is 1001, 731
>> Coordinate System is `'
>> Origin = (399750.000000000000000,6410250.000000000000000)
>> Pixel Size = (500.000000000000000,-500.000000000000000)
>> Metadata:
>>   AREA_OR_POINT=Point
>> Corner Coordinates:
>> Upper Left  (  399750.000, 6410250.000)
>> Lower Left  (  399750.000, 6044750.000)
>> Upper Right (  900250.000, 6410250.000)
>> Lower Right (  900250.000, 6044750.000)
>> Center      (  650000.000, 6227500.000)
>> Band 1 Block=1001x1 Type=Float32, ColorInterp=Undefined
>>   NoData Value=9999
>> As expected, the upper left corner is shifted half a pixel. It is my
>> understanding, that GDAL (GetGeoTransform) always uses the xulcorner,
>> yulcorner (pixel) interpretation. However, I was suprised to see that after
>> a
>> gdal_translate dkgeoid13b.utm32 hello.tif,  I get:
>> >gdalinfo hello.tif
>> Driver: GTiff/GeoTIFF
>> Files: hej.tif
>> Size is 1001, 731
>> Origin = (400000.000000000000000,6410000.000000000000000)
>> Image Structure Metadata:
>>   INTERLEAVE=BAND
>> Corner Coordinates:
>> Upper Left  (  400000.000, 6410000.000)
>> Lower Left  (  400000.000, 6044500.000)
>> Upper Right (  900500.000, 6410000.000)
>> Lower Right (  900500.000, 6044500.000)
>> Center      (  650250.000, 6227250.000)
>> Band 1 Block=1001x2 Type=Float32, ColorInterp=Gray
>>   NoData Value=99
>> The GeoTransform is not shifted half a pixel, and is not the same as the
>> AAIGRID i ran gdal_translate on?? So, I would have to interpret now the
>> GeoTransform as xulcenter and yulcenter. This came as a suprise, and led to
>> some bugs in our processing software.
>> Is this to be expected??
>> Cheers,
>> Simon Kokkendorff
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20151119/d5de26c4/attachment.html>
