[gdal-dev] Reading DNC nautical charts
Damian Dixon damian.dixon at gmail.com
Sat Nov 21 22:47:15 PST 2015
DNC is based on VPF format.
http://msi.nga.mil/NGAPortal/DNC.portal;jsessionid=v7pkSThJG9vQcrQ0yTwLxTL1hQmyhGbFJQLZCJTW5dGJJjT0GmJX!1413119135!NONE?_nfpb=true&_st=&_pageLabel=dnc_portal_page_70&faqCode=02
The styling is defined by a different standard as a set of geosym rules.
Regards
Damian
On 22 Nov 2015 05:59, "Nicolas Cadieux" <nicolas.cadieux at archeotec.ca>
wrote:
> Hi,
> If you have a link to the charts, I could look at it and see the format
> and see if they are georeferenced (if coordinates like longitude and
> latitudes is included in the image file).  They should be.  If so, I would
> recommend you use a GIS software like QGIS to visualise the maps  and
> manipulate the map.  QGIS has plugins that will permit you to plug in a GPS
> and to track the movement for navigation.
>  QGIS uses the GDAL library to open, save and manipulate maps images
> (rasters)  and point, line and polygons (vector data) so you get all the
> power of GDAL and a user friendly interface.
> Nicolas Cadieux M.Sc.
> Les Entreprises Archéotec inc.
> 8548, rue Saint-Denis Montréal H2P 2H2
> Téléphone: 514.381.5112  Fax: 514.381.4995
> www.archeotec.ca
> On Nov 20, 2015 4:13 PM, Hans Rijsdijk <hrijsdijk at gmail.com> wrote:
> > Can anyone advise if DNC nautical charts can be used on the gdal
> software and, if so even better with a gps? In other words for navigation.
> > I am not familiar with gdal software so a 'fatherly' response will be
> greatly appreciated.
> > Cheers
> > Hans
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20151122/19599019/attachment.html>
