[gdal-dev] RFC 48: Geographical networks support
Dmitry Baryshnikov
bishop.dev at gmail.com
Mon Nov 23 00:14:24 PST 2015
Hi Paul,
The RFS48 implemented, but only in trunk. The plan for release was on
GDAL 2.1.
Yes, you can create shortest path between 2 points using a shapefile of
roads, but the graph needed to be created. The autocreate method
developed mostly for points (valves) and lines (tubes) so it may be
unusable for you case in current implementation.
The details is here:
https://github.com/OSGeo/gdal/blob/trunk/gdal/gnm/gnm_tut.dox
https://github.com/OSGeo/gdal/blob/trunk/gdal/gnm/gnm_arch.dox
https://github.com/OSGeo/gdal/blob/trunk/gdal/apps/gnm_utilities.dox
Also, I would like to note, what GNMGenericNetowrk is not optimized now
for big datasets (all graph stored in memory).
Best regards,
Dmitry
23.11.2015 10:50, Paul Meems пишет:
> Hi List,
> I'm looking at this RFC. Is it already implemented in GDAL v2?
> And can we use it to create the shortest path between 2 points using a
> shapefile of roads (linestring)
> Thanks,
> Paul
> *Paul Meems *
> Release manager, configuration manager
> and forum moderator of MapWindow GIS.
> www.mapwindow.org <http://www.mapwindow.org/>
> Owner of MapWindow.nl - Support for
> Dutch speaking users.
> www.mapwindow.nl <http://www.mapwindow.nl/>
> *We've started with the development of MapWindow v5. Read more.
> <http://www.mapwindow.org/documentation/mapwingis4.9/MapWindow49.html>
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20151123/93a6fe8a/attachment.html>
