[gdal-dev] does OGR GML support multiple geometries
Even Rouault
even.rouault at spatialys.com
Tue Nov 24 05:54:30 PST 2015
Luc,
> <xsd:element
> name="MyDualGeomFeature"
> type="test:MyDualGeomFeature"
==> This should by type="test:MyDualGeomFeatureType"
Once corrected, with GDAL 1.11 or above :
$ ogrinfo ../../trunk/gdal/test.gml -al
Had to open data source read-only.
INFO: Open of `../../trunk/gdal/test.gml'
using driver `GML' successful.
Layer name: MyDualGeomFeature
Geometry (centerline): Line String
Geometry (centerOf): Point
Feature Count: 1
Extent (centerline): (30.095473, -96.079963) - (30.095473, -96.079963)
Extent (centerOf): (30.095473, -96.079963) - (30.095473, -96.079963)
SRS WKT (centerline):
(unknown)
SRS WKT (centerOf):
(unknown)
Geometry Column 1 = centerline
Geometry Column 2 = centerOf
gml_id: String (0.0)
componentID: String (0.0)
OGRFeature(MyDualGeomFeature):1
gml_id (String) = myMyDualGeomFeature1
componentID (String) = test1
centerline = POINT (30.095472861000079 -96.079962906)
centerOf = POINT (30.095472861000079 -96.079962906)
Even
http://www.spatialys.com
