[gdal-dev] gdalwarp fails to warp for this GeoPDF
Jean-Claude Repetto
jrepetto at free.fr
Thu Oct 1 02:28:49 PDT 2015
Le 01/10/2015 10:42, Even Rouault a écrit :
> I don't think so. Looks like an issue with your GDAL and/or proj.4 install.
> The proj.4 string for EPSG:3857 reported above is wrong. It should be (as reported by gdalsrsinfo "EPSG:3857"):
> +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext +no_defs
It fails also here. I think that the problem comes from the projection
parameters stored in the PDF file (the scale factor is null).
