[gdal-dev] Allocate large memory space with CPLMalloc(). Bug or not?
Even Rouault
even.rouault at spatialys.com
Thu Oct 1 12:37:12 PDT 2015
Le jeudi 01 octobre 2015 21:18:33, fazotron a écrit :
> Hello!
> Take a look on the following code:
> size_t w = 10000, h = 5000, d = 150;
> size_t sz = w * h * d * sizeof(float); // ~27.94 Gb
> float *volume = (float*)CPLMalloc(sz);
> In this case GDAL throws error in runtime: "ERROR 1: CPLMalloc(-664771072):
> Silly size requested."
> But I think that it's not silly, because such amount of free RAM is
> available on my system. For example I can successfully allocate it calling
> standart malloc().
> I have opened CPLMalloc() source code and seen the following lines:
> *void *CPLMalloc( size_t nSize )
> if( long(nSize) < 0 )
> CPLError( CE_Failure, CPLE_AppDefined,
> "CPLMalloc(%ld): Silly size requested.\n",
> (long) nSize );
> return NULL;
> In my case long( size_t nSize ) returns negative value and it leads to
> error.
> As far as I understand converting one integer type to another smaller
> integer type (e.g. long long/size_t to long) is implementation-defined, so
> it's not safe to use CPLMalloc() with 64-bit integers.
CPLMalloc() is not meant at being used for big allocations since it aborts if
the allocation fails. Use VSIMalloc() instead that will return NULL in case of
failed alloc
> http://osgeo-org.1560.x6.nabble.com/Allocate-large-memory-space-with-CPLMa
> lloc-Bug-or-not-tp5227443.html Sent from the GDAL - Dev mailing list
> archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
