[gdal-dev] MDB tools
Stefan Keller
sfkeller at gmail.com
Fri Oct 2 07:35:33 PDT 2015
Zoltan
Yes, I'm testing GDAL 1.11.2, released 2015/02/10, in Windows which
supports PGeo and Geomedia.
My problem is, how can I tell ogrinfo's and ogr2ogr that myfile.mdb is
Geomedia and not PGeo (since both have fileextension .mdb)?
:Stefan
2015-10-02 15:48 GMT+02:00 Zoltan Szecsei <zoltans at geograph.co.za>:
> Hi,
> Look at http://www.gdal.org/ogr_formats.html
> IIRC ogr2ogr needed that - but ogrinfo? not sure - maybe the -oo param?
> You could also use ogrinfo --formats
> to see what's available on your system.
> Hopefully others will chip in too.
> Regards,
> Zoltan
> On 2015-10-02 15:38, Stefan Keller wrote:
>> I have a similar issue and supposedly a very simple question:
>> Given a file Geomedia .mdb file I'm getting a similar error on Windows.
>> % ogrinfo myfile.mdb -al -so
>> How does OGR recognize if it's a Personal Geodatabase or a Geomedia file?
>> :Stefan
>> 2012-03-28 16:19 GMT+02:00 Paolo Corti <pcorti at gmail.com>:
>>> On Wed, Mar 28, 2012 at 3:57 PM, Zoltan Szecsei <zoltans at geograph.co.za>
>>> wrote:
>>>> Hi All,
>>>> I am trying to find a way to list the data type of each field in all
>>>> tables
>>>> in a GeoMedia MDB databse.
>>>> I tried ogrinfo mdbname and got: ERROR 1: PGeo: MDB Tools driver not
>>>> found!
>>>> so, sudo apt-get install mdbtools, and tried again and got same error.
>>>> so, sudo apt-get install gdal-bin and that gave me a newer version than
>>>> that
>>>> I did have.
>>>> Interestingly apt-get returned: Setting up gdal-bin
>>>> (1.9.0-1~exp5~lucid4)
>>>> ...... etc etc
>>>> but afterwards: ogrinfo --version still returns GDAL 1.8.1, released
>>>> 2011/07/09
>>> As you are on Linux, you should avoid the rely on ODBC, and use the
>>> Geomedia driver [1], only available from gdal 1.9.
>>> I would test it for you, but I have no Geomedia sample data for testing
>>> p
>>> [1] http://www.gdal.org/ogr/drv_geomedia.html
>>> Paolo Corti
>>> Geospatial software developer
>>> web: http://www.paolocorti.net
>>> twitter: @capooti
>>> skype: capooti
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Zoltan Szecsei PrGISc [PGP0031]
> Geograph (Pty) Ltd.
> GIS and Photogrammetric Services
> P.O. Box 7, Muizenberg 7950, South Africa.
> Mobile: +27-83-6004028
> Fax: +27-86-6115323 www.geograph.co.za
