[gdal-dev] Python gdal catch ERROR 6
Luca Delucchi lucadeluge at gmail.com
Wed Oct 7 06:15:20 PDT 2015
Hi devs,
PDF driver is actually supporting only 8 bit band, and if I try to
create a layer using CreateCopy function with a dataset different from
8 bit I get "ERROR 6: PDF driver doesn't support data type UInt16.
Only eight bit byte bands supported."
I try to catch this error using try/except but it doesn't work, should
I test if the result of CreateCopy is not None? Is there any other
better way to catch this error?
thanks
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
