[gdal-dev] Looking for FileGeoDB Writer
Even Rouault
even.rouault at spatialys.com
Thu Oct 8 06:39:01 PDT 2015
Le jeudi 08 octobre 2015 15:30:47, Gane R a écrit :
> Hi all,
> I see the OpenFileGDB supports only reading. Is any driver supporting write
> filegeodb other than ESRI FileGeoDB driver ?
Gane,
no, for write support, you need currently to sue the (ESRI SDK based) FileGDB
driver.
Write support in OpenFileGDB could potentially be added, with the exception of
spatial indexes whose format hasn't been successfully reverse engineered up to
now.
Even
> Gane
http://www.spatialys.com
