[gdal-dev] gdalUtils (GDAL/OGR for R) now on CRAN
Even Rouault even.rouault at spatialys.com
Fri Oct 9 11:27:31 PDT 2015
Le vendredi 09 octobre 2015 19:43:28, Jonathan Greenberg a écrit :
> Folks:
> I wanted to let you know I've pushed a major release of my gdalUtils
> package to CRAN in the last week.  This wraps all non-python GDAL/OGR
> utilities as of GDAL 2.0.1 for use in R, and provides some value-added
> functions as well.
> install.packages("gdalUtils")
> should work for all OSs, or if you want the bleeding edge version, use:
> install.packages("gdalUtils", repos="http://R-Forge.R-project.org")
> Note this is not the same as rgdal -- my package simply wraps the gdal
> binaries, which must be pre-installed by the user.
Jonathan,
You might take advantage of the librarification of those utilities that is
currently taking place for GDAL 2.1 (work in progress) :
https://trac.osgeo.org/gdal/wiki/rfc59.1_utilities_as_a_library
Even
> Cheers!
> --jonathan
http://www.spatialys.com
