[gdal-dev] List of reasonable default parameters for each projection
Ray Gardener rayg at daylongraphics.com
Sun Oct 11 12:09:52 PDT 2015
I was wondering if there is a list, for each projection supported by
OGR, reasonable default values for each projection parameter. For
example, if the user is switching projections in an app, a small table
listing the projection parameters appears, but they need to be populated
with reasonable default values.
e.g. for the New Zealand Mining Grid, one could do
spatialRef.SetNZMG(centerLat = 41, centerLong = 173,
falseEasting=2510000, falseNorthing=6023150);
Ray
