[gdal-dev] GDAL precision for Geometry object
Even Rouault
even.rouault at spatialys.com
Mon Oct 12 02:28:17 PDT 2015
> @Even: I also tried to imagine a reasonable real-life coordinate value
> that would generate scientific notation when printed with "%.15g" or:
> "%.17g" (as hamish mentioned in this old ticket). Can you point me to one?
No, it is unlikely that coordinates go that big in any reasonable projected
coordinate system. Unless perhaps if you are far away from the validity area
of the PCS.
I've changed to '%.15g' formatting for WKT in
https://trac.osgeo.org/gdal/ticket/6145
> Hermann
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
