[gdal-dev] How connect to a remote oracle with spatial
Andrea Peri aperi2007 at gmail.com
Wed Oct 14 00:51:10 PDT 2015
thx for help.
The solution reported me from Rèmy work good.
My error was to use the ":" instead of "/" to separate username and password.
So the right sintax is:
ogrinfo OCI:username/password@"(DESCRIPTION = (ADDRESS_LIST = (ADDRESS
= (PROTOCOL = TCP)(HOST = <IP server dbms>)(PORT = <listener
port>)))(CONNECT_DATA = (SID =<the sid of dbms>))):<schema>.<table>"
Regards.
2015-10-14 9:36 GMT+02:00 Rémy Gourrat <rgourrat at ag-carto.fr>:
> Hi,
> You put a : instead /
> You must use this syntax :
> -----Message d'origine-----
> De : gdal-dev [mailto:gdal-dev-bounces at lists.osgeo.org] De la part de Andrea Peri
> Envoyé : mercredi 14 octobre 2015 09:33
> À : gdal-dev at lists.osgeo.org
> Objet : [gdal-dev] How connect to a remote oracle with spatial
> Hi,
> I'm trying to test using gdal the access to an oracle dbms.
> To do this I use the ogrinfo and try this sintax but without success.
> ogrinfo OCI:username:password@"(DESCRIPTION = (ADDRESS_LIST = (ADDRESS = (PROTOCOL = TCP)(HOST = <IP server dbms>)(PORT = <listener
> The server return
> ERROR 1: ORA-01005: null password given; logon denied  in <unnamed>
> I guess the sintax is wrong , but don't know how otherwise pass to the connection the url and the SID to the dbms
> Any help is welcome.
> Andrea Peri
> qwerty àèìòù
> gdal-dev mailing list
Andrea Peri
qwerty àèìòù
