[gdal-dev] How to find image footprints instead of envelopes?
Even Rouault
even.rouault at spatialys.com
Wed Oct 14 02:09:48 PDT 2015
Le mercredi 14 octobre 2015 10:55:31, Jukka Rahkonen a écrit :
> Thomas Juntunen <junt0015 <at> umn.edu> writes:
> > Jukka,
> > Have a look at Dan Stahlke's code he wrote when at GINA, I think
> gdal_trace_ooutline will do what you
> want:https://github.com/gina-alaska/dans-gdal-scripts
> > Thomas
> Thanks Thomas,
> By looking at the number of different options and comments in the code this
> tool is very feature rich and obviously used for real production. The
> license seems to be BSD http://www.freebsd.org/copyright/license.html. I
> wonder if this tool could be reviewed and possibly added to GDAL utilities.
Jukka,
I guess that it could make sense for some of them, but that would require a
champion to integrate them, document them, add tests, possibly turn them as
library functions per RFC 59.1, make sure they compile and run fine on all our
targets, etc... and maintain them in the long run. I also see a dependency to
boost (http://www.boost.org/) that we've avoided up to now in GDAL core.
Even
http://www.spatialys.com
