[gdal-dev] GDAL testing
Mateusz Loskot
mateusz at loskot.net
Fri Oct 16 03:01:12 PDT 2015
Hi Kurt,
I'm interested in this topic, so I'd like to pull some more details to
better
understand the idea, if you don't mind.
Kurt Schwehr-2 wrote
> For my production work, I'm not able to use the autotest python code
> because of its non-unittest architecture.
Could you elaborate more on what properties exactly are missing
from the current autotest suite?
IOW, what kind of gap autotest2 fills.
Yes, autotest is not a unit testing suite.
To me, it combines functional/integration/blackbox/system/regression
testing.
> So... I started creating python
> unittest and C++ gunit based tests.
Since you mention unittest, then gmock too?
> The tests are more focused on test isolation than autotest. This allows
> for a lot more parallelism in testing.
Isolation at what level?
I suppose, you mean test case isolation, but not isolation of code/unit
under test.
So, the former means each test case runs in isolated environment,
with exclusive access to files/databases/memory/resources required by
particular test.
For example, each run of ogr_mysql.py, also in parallel, exclusively targets
a 'unique' database.
Correct?
> Here are some samples:
> C++ tests use C++11, gunit, google logging, gflags: (Hoping for C++14
> soon.. e.g. make_unique)
> - autotest2/cpp/port/cpl_conv_test.cc
> <https://gist.github.com/schwehr/13137d826763763fb031> (Yes, this is
> massively boring code)
AFAIS, architecture of tests won't change much, typically, test cases will
target functional modules (drivers).
Or, do you plan for proper unit tests targeting individual
interfaces/classes
in internal implementation of drivers, etc.?
> I'm (mostly) following Google's style guides.
> All C++ should be formatted with "clang-format --style=Google"
Unless it is not planned to include autotest2 into GDAL source code,
shouldn't it follow GDAL style?
> Would like to eventually do (unsorted):
> - Fuzz testing, ASAN/MSAN/TSAN/Valgrind/Heap checks (I've done some MSAN
> heap checkers by hand)
> - Performance testing - time and memory usage
IMHO, those belong to separate suites.
- Test the C API at the C level
</qoute>
If plain unittests are planned, mocking might be possible.
Best regards,
Mateusz
View this message in context: http://osgeo-org.1560.x6.nabble.com/Re-GDAL-testing-tp5222783p5230596.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
