[gdal-dev] Refactoring: class members clean-up
Mateusz Loskot
mateusz at loskot.net
Sat Oct 17 03:14:44 PDT 2015
On 17 October 2015 at 00:25, Kurt Schwehr <schwehr at gmail.com> wrote:
> I personally like foo_, but m_ is fine.
I personally too, but we should stick to what has already been used in GDAL.
> I worry about unexpected side
> effects of changing member naming with private members.
I don't suggest changing members visibility.
> If we go for changing
> publics, we should pick a time and go for a major version number bump and
> expect a lot of peopIe using GDAL to go through a lot of pain. I see a lot
> of stuff generally like this...
Public members should stay as they are, not renamed.
That is also Even's suggestion.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
