[gdal-dev] OGR error handling
    Even Rouault
    even.rouault at spatialys.com
    Tue Oct 20 12:58:37 PDT 2015
André,
> Hi all,
> We are using OGRSFDriver::CopyDataSource() to copy a GML data source to a
> memory data source on v1.11.x.
> We have encountered a problem where one of the feature tags of a particular
> GML file we are trying to read is malformed. What we are seeing is that an
> error occurs in OGRGMLLayer::GetNextFeature(), which gets reported as
> expected via CPLError().
> The problem we are faced with is that that error seems to be reset using
> CPLErrorReset() before control returns to the caller of CopyDataSource(),
> specifically in OGRDataSource::CopyLayer(). The result is that the copying
> silently skips over problematic features.
I'm not clear of the reason for those CPLErrorReset() in CopyLayer(). I guess
you could remove them without trouble.
If you don't want to modify GDAL sources, a workaround would be to install
your own error handler with CPLSetErrorHandler() or CPLPushErrorHandler() so
as to note the error.
Even
http://www.spatialys.com
