[gdal-dev] Weird OpenFileGDB error
Roger André
randre at gmail.com
Wed Oct 21 12:03:11 PDT 2015
Hi All,
I've been trying unsuccessfully to extract a feature class from a large
file geodatabase. While many of the other feature classes in it are read
properly, on this one I get the following error:
$ ogrinfo -summary file.gdb Streets
Had to open data source read-only.
INFO: Open of `file.gdb'
using driver `OpenFileGDB' successful.
Layer name: Streets
Geometry: Multi Line String
ERROR 1: Error occured in filegdbtable.cpp at line 768
Line 768 is part of this block of code:
if( byFieldType > FGFT_XML)
CPLDebug("OpenFileGDB", "Unhandled field type : %d",
byFieldType);
returnError(); <---- line 768
Can any of you provide me some suggestions for how I can trace the specific
cause of this problem more precisely? Unfortunately, this is commercial
data which I can't share with you, but I'd be happy to try to diagnose the
problem more thoroughly.
Thanks,
Roger
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20151021/2fb232af/attachment.html>
