[gdal-dev] error parsing metadata from HDF5 dataset
Rashad M
mohammedrashadkm at gmail.com
Thu Sep 3 07:58:34 PDT 2015
Hello all,
I have an problem when reading metadata information of HDF5 dataset. some
of the values are not parsed properly by GDAL. Below is the relevant part
of output from gdalinfo
Azimuth_Processing_Number_of_Looks=
Bits_per_Sample=
S01_B001_Azimuth_Ramp_Code=
<garbage values and newline chars>
Sample_Format=INT
Samples_per_Pixel=
Satellite_Height=628440.5
Satellite_ID=CSKS3
I had looked into frmts/hdf5/hdf5dataset.cpp and all of these metadata are
of type H5T_NATIVE_UCHAR.
https://trac.osgeo.org/gdal/browser/branches/1.11/gdal/frmts/hdf5/hdf5dataset.cpp#L728
changing format specifier from char( %c) to int(%d) solves the issue for
me. But is there a better fix for this?
OS: Fedora 20 x86_64
gdal branch: 1.11
svn info
Path: .
Working Copy Root Path: /home/mkanavat/sources/gdal_branch_1.11
URL: http://svn.osgeo.org/gdal/branches/1.11/gdal
Relative URL: ^/branches/1.11/gdal
Repository Root: http://svn.osgeo.org/gdal
Repository UUID: f0d54148-0727-0410-94bb-9a71ac55c965
Revision: 30007
Node Kind: directory
Schedule: normal
Last Changed Author: rouault
Last Changed Rev: 30005
Last Changed Date: 2015-09-01 10:17:50 +0200 (Tue, 01 Sep 2015)
Regards,
Rashad
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150903/1dad5b39/attachment.html>
