[gdal-dev] vector VRT: Warning 1: Line 2: Attribute value should be single or double quoted.
Helmut Kudrnovsky
hellik at web.de
Fri Sep 4 00:24:33 PDT 2015
Luke wrote
> VRT is an XML file, and to be valid XML all attribute values in the VRT
> need to be quoted.
> e.g
> <element_name attribute_name="attribute_value">
> In your VRT, your relativeToVRT attribute value is not quoted. Change
> <SrcDataSource relativeToVRT=1>
> to
> <SrcDataSource relativeToVRT="1">
> Luke
thanks for the hints ; it's working now.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/vector-VRT-Warning-1-Line-2-Attribute-value-should-be-single-or-double-quoted-tp5221290p5222631.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
