[gdal-dev] ArcSDE Direct Connect Support
Fletcher, Stuart (DPIPWE)
Stuart.Fletcher at dpipwe.tas.gov.au
Mon Sep 7 19:49:03 PDT 2015
Hi there,
Has anyone managed to compile GDAL with support for ArcSDE Direct Connect Libraries. The ArcSDE SDK includes library files for this however there doesn't appear to be any compile flags within GDAL. We are using --with-sde=/home/gdal/ArcSDE-10.2 --with-sde-version=102
This however only uses the following:
libsde.so
libpq.so
libpe.so
We would like to compile with support for Oracle 11g the sdk includes these libraries:
libsdeora11gsrvr102.so
libgsrvrora11g102.so
Any advice or assistance would be greatly appreciated.
Thanks,
Stuart Fletcher
CONFIDENTIALITY NOTICE AND DISCLAIMER
The information in this transmission may be confidential and/or protected by legal professional privilege, and is intended only for the person or persons to whom it is addressed. If you are not such a person, you are warned that any disclosure, copying or dissemination of the information is unauthorised. If you have received the transmission in error, please immediately contact this office by telephone, fax or email, to inform us of the error and to enable arrangements to be made for the destruction of the transmission, or its return at our cost. No liability is accepted for any unauthorised use of the information contained in this transmission.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150908/14a8d258/attachment.html>
