[gdal-dev] Transform raster based on values in shapefile attribute table
jramm jamessramm at gmail.com
Thu Sep 17 07:37:01 PDT 2015
I have a raster (.tif), which has an accompanying shapefile attribute table
(.dbf). Basically, every value in the raster is a key into the attribute
table, which has a number of fields (there is a 'Value' field which is the
'key' corresponding to the raster values, then a number of attributes).
I want to derive a new raster based on a specific field in the attribute
table. I.e. for each pixel in the raster, find the corresponding row in the
attribute table, get the value of the desired field and replace the pixel
value with this new value.
What (if anything) does GDAL provide to enable me to do this efficiently? Is
there an efficient method to look up rows (which in the OGR model I suppose
correspond to features) based on the value of a field?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Transform-raster-based-on-values-in-shapefile-attribute-table-tp5224659.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
