[gdal-dev] ogr2ogr convert geojson to MapInfo tab
Even Rouault
even.rouault at spatialys.com
Thu Sep 17 09:30:45 PDT 2015
Le jeudi 17 septembre 2015 18:21:24, Maxime Demers a écrit :
> Hi Even,
> Sorry to reply you in a new thread. I have realize my mail-list settings
> was set to not send me replies. I have found your reply in the archive.
> Thank you for your answer. I am a bit desapointed that no solution exists
> for now, and I dont think I would be able to test with the trunk version
> because I am on windows and dont know how to build gdal from sources.
There are daily builds of trunk at :
http://gisinternals.com/development.php
So have a look tomorrow (look for rows with a revision number > 30500,
sometimes some targets are stuck with older revisions)
> Do you have an idea, if the solution could be merged into a binary release
> for windows soon?
> Salutations,
> Maxime Demers
> <http://www.lastfm.fr/user/burton449>
> >* Hello,
> *> >* I encounter a problem using ogr2ogr (from gdal 1.10) when trying
> to convert
> *>* a geojson to MapInfo Tab. The output MapInfo tab does not include the
> *>* projection wich is defined in the geojson as EPSG:3857 so srs is
> defined as *>* WGS84 as default.
> *> >* I think its a known problem with MapInfo Tab (mitab driver) but
> I dont know
> *>* if a solution exist. Anybody can help?*
http://www.spatialys.com
