[gdal-dev] PDF gets skewed and shifts in geo location raster GeoTIFF
Even Rouault
even.rouault at spatialys.com
Wed Sep 23 01:12:41 PDT 2015
Gane,
I don't really understand what you mean. Is there an error in the PDF
georeferencing (I thought we had addressed that a few months ago), or are you
surprised that gdalwarp transforms the image to be north-up ? If it is the
later, then it is an intended behaviour of gdalwarp.
Best regards,
Even
> There are cases for handling 90 -90 rotation in pdfdataset.cpp
> I am using poppler with pdfdataset.cpp as in Revision: 28978 of trunk
> PDF gets skewed and shifts in geo location raster GeoTIFF, Is there any
> issue in computing the geotransform ?
> GeoTransform values are for an pdf at EPSG:4326
> 10776
> 6682
> -87.844995622259475
> 0.000001374506717
> 0.000000429963146
> 42.847234964542217
> 0.000000580102585
> -0.000001012112732
> Corresponding GeoTransform for GeoTiff in EPSG:3857 after gdalwarp
> 12529
> 10422
> GeoTransform values
> -9779291.683092894000000
> 0.166040058992803
> 0.000000000000000
> 5290478.766616309100000
> 0.000000000000000
> -0.166040058992803
http://www.spatialys.com
