[gdal-dev] ogr2ogr - geojson to mapInfo - size of .dat become too big
Maxime Demers burton449geo at gmail.com
Wed Sep 23 05:41:53 PDT 2015
Hi Even,
Thank you for the suggestion. However, it seems I cannot use such a -sql
statement on a geojson file. I got the following error with the command
below:
ogr2ogr -f "MapInfo File" test.tab points.geojson -sql "select cast(id as
integer(10)), cast(codecs as character(3)), cast(codeSecteur as
character(20)), cast(codeWork as character(20)), cast(codePostal as
character(6)) from points"
ERROR 1: SELECT from table points failed, no such table/featureclass.
However, I have no problem to use the same command to convert a MapInfo
File to another MapInfo File with the -sql statement. Are you able to
confirm if its possible to do a -sql statement on a geojson file and if
yes, do you know why I got this error?
thank you,
Maxime Demers
On Tue, Sep 22, 2015 at 2:47 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Le mardi 22 septembre 2015 16:07:56, Maxime Demers a écrit :
> > Hi,
> > I have notice something bad when converting a geojson to mapInfo tab with
> > ogr2ogr. The .dat which contain the table feature's properties is getting
> > way too big after conversion.
> > To test, I have converted a mapInfo tab to geojson using:
> > ogr2ogr -f "GeoJSON" test.geojson test.tab
> > and then I converted it back to mapInfo tab using:
> > ogr2pgr -f "MapInfo File" test2.tab test.geojson
> > Before convertion, the .dat of the mapInfo file was 8,75 Mo after
> > conversion it became 105 Mo.
> > I dont know if the problem is only when converting geojson to mapInfo
> tab.
> > What could be the cause of the problem and does a solution exists?
> Maxime,
> The issue is that when converting from GeoJSON to .tab, the source text
> fields in GeoJSON have no longer an explicit field width, hence the mapinfo
> driver fallbacks to 254 characters.
> You could workaround with a statement like this :
> ogr2ogr  -f "MapInfo File" test2.tab test.geojson -sql "select
> cast(field1_name as character(field_width)), cast(field2_name as
> character(field2_width)), ... from layername"
> to specify explicit field width.
> It would have been great if ogr2ogr had a mode to automate this (I thought
> there was one already, but can't find it)
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
Stack Overflow: http://stackoverflow.com/users/1914034/burton449
GIS Overflow: http://gis.stackexchange.com/users/14426/burton449
LastFm: http://www.lastfm.fr/user/burton449
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150923/565589d1/attachment-0001.html>
