[gdal-dev] Unable to find driver 'MYSQL' after successful config and make
Nicholas Williams
nicholas+osgeo at nicholaswilliams.net
Wed Sep 23 08:29:42 PDT 2015
I'm having trouble getting ogr2ogr working with MySQL on Ubuntu 12.04, but
I can't figure out why. Configure says MySQL is enabled, but execution says
it's not.
In addition to other dependencies, I installed the MySQL client dev:
sudo apt-get install -y libmysqlclient-dev=5.5.28-rel29.1-334.precise
And I confirmed that mysql_config exists and is executable:
# ls -al /usr/bin/mysql_config
-rwxr-xr-x 1 root root 6933 Oct 25 2012 /usr/bin/mysql_config
I configured, made and installed:
./configure --prefix=/usr --with-spatialite=yes --with-libjson-c=internal
--with-mysql=yes
make
make_install
The configure output suggests that MySQL support is enabled. I've
abbreviated it below, but I can post the entire output on request:
checking for mysql_config... /usr/bin/mysql_config
checking for MySQL... yes
GDAL is now configured for x86_64-unknown-linux-gnu
Installation directory: /usr
C compiler: gcc -g -O2
C++ compiler: g++ -g -O2
LIBTOOL support: yes
cURL support (wms/wcs/...):yes
PostgreSQL support: no
MySQL support: yes
Expat support: no
libxml2 support: no
SQLite support: yes
PCRE support: no
SpatiaLite support: yes
I would think the "MySQL support: yes" and "checking for MySQL... yes"
would be fairly concrete. Additionally, I have scoured the make output, and
there were no errors or warnings around any of the MySQl stuff. So, it
should work, right? Apparently not:
# ogr2ogr --format mysql
ERROR 1: --format option given with format 'mysql', but that format not
recognised. Use the --formats option to get a list of available formats,
and use the short code (ie. GTiff or HFA) as the format identifier.
# ogr2ogr -f MYSQL MYSQL:"geo,tables=Time_Zone_Polygons" -nln
Time_Zone_Polygons -nlt POLYGON \
-update -append -progress -gt 40000 -fieldmap 2 \
-lco ENGINE=MYISAM -lco LAUNDER=yes -lco FID=id -lco FID64=TRUE -lco
GEOMETRY_NAME=region tz_world.shp
Unable to find driver `MYSQL'.
The following drivers are available:
-> `PCIDSK'
... (no MySQL anywhere)
Can I get some help/advice figuring out what went wrong?
Thanks,
Nick
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150923/07a569b6/attachment-0001.html>
