[gdal-dev] IAU2000 support?
Even Rouault even.rouault at spatialys.com
Thu Sep 24 05:13:14 PDT 2015
Le jeudi 24 septembre 2015 14:10:37, Yann a écrit :
> sorry, I get this from Ubuntu, thus my question.
> gdalsrsinfo urn:ogc:def:crs:IAU2000:30100
> ERROR 1: ERROR - failed to load SRS definition from
I think this dates back to ancient GDAL versions but you need to add the
iau2000.wkt file in the GDAL data directory.
> On 24/09/2015 11:45, Even Rouault wrote:
> > Yann,
> >> I have recovered a old script I made about 1.5 year ago (and about 1+
> >> version of Ubuntu away) to process Chandrayaan-M3 Moon data in
> >> IAU2000:30100 and it seems that gdal_translate/gdalwarp do not know that
> >> code anymore.
> > Looking at the code you need to use a OGC URN:
> > $ gdalsrsinfo urn:ogc:def:crs:IAU2000:30100
> > PROJ.4 : '+proj=longlat +a=1737400 +b=1737400 +no_defs '
> > OGC WKT :
> > GEOGCS["Moon 2000",
> >      DATUM["D_Moon_2000",
> >          SPHEROID["Moon_2000_IAU_IAG",1737400.0,0.0]],
> >      PRIMEM["Greenwich",0],
> >      UNIT["Decimal_Degree",0.0174532925199433]]
> >> This is not a blocker, since the wkt style works like a charm.
> >> We had discussions earlier about planetary support in this list, among
> >> whom Trent was involved (IIRC). Does anybody have any update about the
> >> status change for the newest version of GDAL?
> > Status quo.
> > Even
http://www.spatialys.com
