[gdal-dev] Huge Memory Consumption of GDALDefaultOverviews::Initialize
Julian Zeidler gdal at zeidlers.de
Wed Apr 6 05:42:42 PDT 2016
Hey all,
I have the Problem that my cpp-Code which exclusively uses gdal for IO
suddenly uses vast Amounts of memory in a production environment.
When i analyzed the memory foot-print (via valgrind  massif) it turns
out that 95% (in the test case ==7.8GB! RAM) is allocated by gdal in
at the line  papszInitSiblingFiles = CSLDuplicate(papszSiblingFiles);
(gdaldefaultoverviews.cpp:155, i am running gdal 1.11.2, but code is
identical on github)
The call history is:
80.48% (8,291,659,680B) (heap allocation functions) malloc/new/new[],
--alloc-fns, etc.
->78.78% (8,116,771,916B) 0x53C1A51: CPLMalloc (cpl_conv.cpp:136)
| ->67.21% (6,924,674,689B) 0x53C1B6A: CPLStrdup (cpl_conv.cpp:255)
| | ->67.21% (6,924,640,837B) 0x53D6BC3: CSLDuplicate (cpl_string.cpp:220)
| | | ->67.21% (6,924,640,800B) 0x538A7CA:
GDALDefaultOverviews::Initialize(GDALDataset*, char const*, char**, int)
(gdaldefaultoverviews.cpp:155)
| | | | ->67.21% (6,924,640,800B) 0x51C67C6:
GTiffDataset::Open(GDALOpenInfo*) (geotiff.cpp:6437)
| | | |   ->67.21% (6,924,640,800B) 0x53887FB:
GDALOpenInternal(GDALOpenInfo&, char const* const*) (gdaldataset.cpp:2314)
| | | |     ->67.21% (6,924,640,800B) 0x5388A24: GDALOpenInternal(char
const*, GDALAccess, char const* const*) (gdaldataset.cpp:2263)
The CornerCases are my Programm opens ~300 geotiffs for Reading from a
Folder with ~450.000 Files in it.
Is there any way i can have gdal not check for overviews or how i can
free this memory? After opening a tiff file?
And should gdal be hogging this much memory while it is just checking
for external overviews?
Cheers
Julian Zeidler
