[gdal-dev] Bad Date Handling
Even Rouault even.rouault at spatialys.com
Tue Apr 12 11:58:04 PDT 2016
Le mardi 05 avril 2016 21:09:01, Even Rouault a écrit :
> Le mardi 05 avril 2016 20:56:07, Paul Ramsey a écrit :
> > Hey all,
> > We've had a client working with dodgy data who would like an option to
> > avoid incompatible date mangling when reading bad data. Basically, OGR
> > will consume some funky dates from CSV and Excel, like 0000/00/00, but
> > it will NULL out others, like 1971/34/34. The net result is that, when
> > the data are written out to PgSQL, is some null values, and other
> > values that get converted to things PgSQL cannot consume (0000/00/00
> > becomes 2000/00/00 and PgSQL then errors out on that).
> > They'd like to just coerce *all* invalid dates to NULL,
> > I've done a small patch that does that, in the presence of a config
> > flag, any thoughts on if it's acceptable?
> Paul,
> Why not rather improving the datetime parser to reject invalid dates like
> 0000/00/00 ? In OGRParseDate() in ogr/ogrutils.cpp. That way that would
> solve the issue not only for Postgres output, but for all other drivers.
FYI, a different issue but with same root cause has been just reported as
https://trac.osgeo.org/gdal/ticket/6452 , which I've fixed.
Even
http://www.spatialys.com
