[gdal-dev] Rectify TIFF: Difference between applied GCP and warped image
Bischof, Richard
Richard.Bischof at lgln.niedersachsen.de
Wed Apr 13 00:31:26 PDT 2016
Hi Jukka,
you're correct. ArcMap is doing the on-the-fly transformation with the dataset, I applied the gcps using gdal_translate to.
With both gdal_warp and ArcMap Rectify I use second order polynomial.
I also found, that some areas of my source image are cut out from the gdal_warp destination dataset.
Here are my gdalinfos to the files:
Input Dataset with gcp:
Driver: GTiff/GeoTIFF
Files: gdal_translate.tif
Size is 6132, 5940
Coordinate System is `'
GCP Projection =
GCP[ 0]: Id=1, Info=
(5734.32993305,4261.44895879) -> (611521.018414,5787817.29357,0)
GCP[ 1]: Id=2, Info=
(572.485136268,3616.16282333) -> (612191.853158,5789322.98631,0)
GCP[ 2]: Id=3, Info=
(938.059974162,5259.97607362) -> (611658.464864,5789364.12734,0)
GCP[ 3]: Id=4, Info=
(399.270774586,4637.53045143) -> (611897.913259,5789465.33066,0)
GCP[ 4]: Id=5, Info=
(175.9077093,3518.3785654) -> (612261.413077,5789435.00343,0)
GCP[ 5]: Id=6, Info=
(65.1081071915,1318.06325259) -> (612926.481389,5789252.39979,0)
GCP[ 6]: Id=7, Info=
(2058.05461478,861.869252792) -> (612872.84906,5788621.71163,0)
GCP[ 7]: Id=8, Info=
(3197.85958388,934.608945675) -> (612747.965477,5788289.12972,0)
GCP[ 8]: Id=9, Info=
(4888.93938213,1463.60781341) -> (612426.762337,5787815.07664,0)
GCP[ 9]: Id=10, Info=
(5126.7206471,3450.97792497) -> (611812.932465,5787930.73745,0)
GCP[ 10]: Id=11, Info=
(4165.58848947,4831.95198662) -> (611488.508427,5788352.14431,0)
GCP[ 11]: Id=12, Info=
(1596.03095142,4691.55418917) -> (611766.991386,5789112.70647,0)
GCP[ 12]: Id=13, Info=
(2611.86113409,5865.48875961) -> (611315.082149,5788919.03108,0)
GCP[ 13]: Id=14, Info=
(1753.54106193,2650.51125969) -> (612364.509943,5788875.28655,0)
GCP[ 14]: Id=15, Info=
(3623.30422048,166.767269129) -> (612934.192512,5788086.76226,0)
GCP[ 15]: Id=16, Info=
(3033.49120733,4610.79484584) -> (611663.462367,5788668.84676,0)
Metadata:
COLORSPACE=GREYSCALE
COMPRESSION_RATE_TARGET=1
VERSION=2
Image Structure Metadata:
INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 5940.0)
Upper Right ( 6132.0, 0.0)
Lower Right ( 6132.0, 5940.0)
Center ( 3066.0, 2970.0)
Band 1 Block=6132x1 Type=Byte, ColorInterp=Gray
Description = Grayscale
Metadata:
DESCRIPTION=Grayscale
Output gdal_warp:
Files: gdal_translate-gdal_warp.tif
gdal_translate-gdal_warp.tfw
Size is 7464, 7627
Origin = (610977.126584137670000,5789708.876662718100000)
Pixel Size = (0.314972716042089,-0.314972716042089)
Metadata:
VERSION=2
COMPRESSION=LZW
INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( 610977.127, 5789708.877)
Lower Left ( 610977.127, 5787306.580)
Upper Right ( 613328.083, 5789708.877)
Lower Right ( 613328.083, 5787306.580)
Center ( 612152.605, 5788507.728)
Band 1 Block=256x256 Type=Byte, ColorInterp=Gray
Metadata:
Output ArcMap:
Files: gdal_translate-arcmap_rectify.tif
gdal_translate-arcmap_rectify.tif.ovr
gdal_translate-arcmap_rectify.tfw
gdal_translate-arcmap_rectify.tif.aux.xml
Size is 5969, 6098
Origin = (610973.234545126210000,5789712.967471394700000)
Pixel Size = (0.395246999999997,-0.395247000000031)
INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( 610973.235, 5789712.967)
Lower Left ( 610973.235, 5787302.751)
Upper Right ( 613332.464, 5789712.967)
Lower Right ( 613332.464, 5787302.751)
Center ( 612152.849, 5788507.859)
Band 1 Block=128x128 Type=Byte, ColorInterp=Gray
Min=0.000 Max=240.000
Minimum=0.000, Maximum=240.000, Mean=98.616, StdDev=85.272
NoData Value=256
Overviews: 2985x3049, 1493x1525, 747x763, 374x382, 187x191
Metadata:
STATISTICS_MAXIMUM=240
STATISTICS_MEAN=98,615651896887
STATISTICS_MINIMUM=0
STATISTICS_STDDEV=85,271724597078
Thanks!
Mit freundlichen Grüßen
Richard Bischof
Landesamt für Geoinformation und Landesvermessung Niedersachsen (LGLN)
- Regionaldirektion Hameln-Hannover -
Dezernat 2 - Geodatenmanagement
Constantinstraße 40, 30177 Hannover
Tel.: +49 511 30245-314
Fax: +49 511 30245-360
mailto:richard.bischof at lgln.niedersachsen.de
www.lgln.de/rd-hm
-----Ursprüngliche Nachricht-----
Von: gdal-dev [mailto:gdal-dev-bounces at lists.osgeo.org] Im Auftrag von Jukka Rahkonen
Gesendet: Dienstag, 12. April 2016 19:34
An: gdal-dev at lists.osgeo.org
Betreff: Re: [gdal-dev] Rectify TIFF: Difference between applied GCP and warped image
Bischof, Richard <Richard.Bischof <at> lgln.niedersachsen.de> writes:
> Hello there,
> I`m trying to rectify a lots of dataset in tiff format using gdal. I'am
using Windows 7 Professional, gdal
> 1.11.2 .
> My steps / commands are:
SNIP
> F:\Projekt\gross\106300.tif D:/temp.tif
> 2) Warp the image using gdalwarp
> gdalwarp -multi -wm 4000 -overwrite -r bilinear -order 2 -co COMPRESS=NONE
-co TFW=YES -co TILED=YES
> D:/temp.tif D:\GDAL\106300.tif
> My problem is, that the output dataset from the second step is not what I
expected. It is warped different,
> than ArcMap is showing me, when I load the output dataset from the first
step. (Including the gcp).
> What am I missing in my gdalwarp command?
Do you mean that ArcMap is doing on-the-fly warping by the ground control
points? Do you know which warping method it is applying then? If it is using
2nd order polynomial then the results should be close your result after the
second step, if something else then not necessarily. Can you warp the image
physically with ArcMap so that you force it to use the 2nd order polynomial?
-Jukka Rahkonen-
> Thank you!
> Richard Bischof
> mailto:richard.bischof <at> lgln.niedersachsen.de
> www.lgln.de/rd-hm
> gdal-dev mailing list
> gdal-dev <at> lists.osgeo.org
