[gdal-dev] Shapefile to SQL Server
Jukka Rahkonen
jukka.rahkonen at maanmittauslaitos.fi
Fri Apr 15 11:16:04 PDT 2016
Bo Victor Thomsen <bo.victor.thomsen <at> gmail.com> writes:
> The shape file in the zip is not in projection espg:4269. It's in
> utm zone 12N. Replace the "-a_srs", "ESPG:4269" with "-t_srs",
> "ESPG:4269" and "-s_srs", "ESPG: code_for_UTM_12N"
> This causes ogr2ogr to reproject you data to the correct projection
And it is written "EPSG" as in European Petroleum Survey Group.
-Jukka Rahkonen-
