[gdal-dev] Python port newcomer
Kurt Schwehr schwehr at gmail.com
Sun Apr 17 10:39:50 PDT 2016
Doc strings would be a great place to start.  That would really help people
take advantage of more of what GDAL has to offer.
On Sat, Apr 16, 2016 at 8:16 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Gregory,
> You can have a look at the tickets identified by the following request
> in the bug tracker:
> https://trac.osgeo.org/gdal/query?status=assigned&status=new&status=reopened&description=~python&or&status=assigned&status=new&status=reopened&summary=~python&col=id&col=summary&col=status&col=type&col=priority&col=milestone&col=component&order=priority
> Beware that not all of them are necessarily valid, or even sometimes
> wishable to fix, or appropriate for a new comer.
> You might also consult https://trac.osgeo.org/gdal/wiki/GdalOgrInPython
> Even
> > Hi guys!
> > I'd like to work on python bindings.
> > Is there anyone specifically working on it?
> > Where do I start from, issues list for it, etc?
> > Thanks,
> > Gregory
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Spatialys - Geospatial professional services
> http://www.spatialys.com
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160417/e27f8370/attachment.html>
