[gdal-dev] geospatialPDF DPI and EXTRA_IMAGES
Even Rouault even.rouault at spatialys.com
Wed Apr 20 03:36:40 PDT 2016
Le mercredi 20 avril 2016 12:06:55, Luca Delucchi a écrit :
> On 20 April 2016 at 12:03, Luca Delucchi <lucadeluge at gmail.com> wrote:
> > On 19 May 2015 at 10:37, Even Rouault <even.rouault at spatialys.com> wrote:
> >> Luca,
> > Hi Even,
> > I'm back on this topic because it seems that EXTRA_IMAGES is not
> > working (at least for me) with GDAL 1.11.3
> > ogr2ogr -f PDF -lco COMPRESS=Deflate -lco DPI=72 -lco WRITE_INFO=NO
> > -lco EXTRA_IMAGES=23hq.jpg,100,100,1 /tmp/provaogr2ogr.pdf idrlag.shp
Those options are supported as *dataset* creation options, so you have to use
-dsco instea of -lco
I've just commited an improvement in trunk so that you will now get a warning.
http://www.spatialys.com
