[gdal-dev] Problem with Shapefile and CRS 2056/21781
Stefan Keller
sfkeller at gmail.com
Sun Apr 24 08:46:45 PDT 2016
2016-04-24 17:34 GMT+02:00 Even Rouault <even.rouault at spatialys.com>:
> Could you post the .prj file ?
Bien sur: I posted both CRS.
Hope attachments come through.
:Stefan
> Le dimanche 24 avril 2016 17:29:36, Stefan Keller a écrit :
>> Given a Shapefile "swiss_admin_boundaries.shp" in EPSG:2056 (or 21781,
>> to be downloaded for free at [1]) I have problems transforming it to
>> any other SRS/CRS.
>> When doing this:
>> > ogr2ogr -f "GPKG" swiss_admin_boundaries1.gpkg swiss_admin_boundaries.shp
>> > -t_srs EPSG:3857
>> ... swiss_admin_boundaries2.gpkg have a shift of about 150m.
>> But when I convert Shapefile first e.g. to GeoPackage, and transform then:
>> > ogr2ogr -f "GPKG" tmp.gpkg swiss_admin_boundaries.shp
>> > ogr2ogr -f "GPKG" swiss_admin_boundaries2.gpkg tmp.gpkg -t_srs EPSG:3857
>> > del tmp.gpkg
>> ... swiss_admin_boundaries2.gpkg is correct!
>> What could be the reason?
>> :Stefan
>> [1] https://opendata.swiss/en/dataset/swissboundaries3d-gemeindegrenzen
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Spatialys - Geospatial professional services
> http://www.spatialys.com
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160424/decf5845/attachment.obj>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160424/decf5845/attachment-0001.obj>
