[gdal-dev] Can't read column name of a gdb file with lattin letters
Tomer
tomerlieber at gmail.com
Mon Apr 25 00:23:43 PDT 2016
I sent this post again because it wasn't sent to the mailing list in the
first time.
I use c# bindings for GDAL and I want to read the column names of a gdb
file.
The problem is that if the column name is written with latin letters, e.g.
Arabic, I get gibberish with less characters than expected.
The problem exists because GDAL uses a string to save column names, and this
type can only contain ascii characters.
Therefore the openFileGdb driver skips on every second byte when reading the
column names of a gdb file.
You can find it in the source code:
File: filegdbtable.cpp
Line: 1689
for(j=0;j < nColNameCarCount;j++) // FIXME> UTF16
osFieldName = pabyCur[2 * j]
Because it's a diffcult to change the column name type to a wstring, which
can contain UTF8 charcaters,
I thought of a creative way to solve the problem.
I read all the bytes of the column name without skipping every second byte
and save the bytes as a string
and then, I get the column name with all the bytes in the c# bindings and
decode them as UTF8.
Here is what i changed in the source code:
Line: 1689
for(j=0;j < 2 * nColNameCarCount;j++)
osFieldName = pabyCur[j]
After I changed the source code and complied it, I still got gibberish with
when I tried to read the column name from the c# bindings, so I couldn't
decode it to UTF8.
My questions is: Why couldn't I read the column names correctly even after
the changes I made?
If someone has another way to deal with this problem, please let me know.
Thanks,
Tomer
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-Can-t-read-column-name-of-a-gdb-file-with-lattin-letters-tp5262714.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
