[gdal-dev] Can't read column name of a gdb file with lattin letters
Tomer
tomerlieber at gmail.com
Tue Apr 26 02:58:36 PDT 2016
If the problem because the null bytes, I still don't understand why I got the
same column name before and after the changes I did in the source code.
That why I guess there is also another problem. Do you know know what it can
be?
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-Can-t-read-column-name-of-a-gdb-file-with-lattin-letters-tp5262714p5262934.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
