[gdal-dev] compile error on windows
Christoph Gohlke cgohlke at uci.edu
Fri Apr 29 14:28:21 PDT 2016
Check the compile options. To use shared libraries of HDF5-1.8.16 on
Windows with Visual Studio you must specify the H5_BUILT_AS_DYNAMIC_LIB
compile definition (see
<https://www.hdfgroup.org/HDF5/release/obtain5.html>).
Christoph
On 4/29/2016 1:17 PM, Ryan Grout wrote:
> Hello,
> I'm attempting to build GDAL for windows using Visual Studio 2008.
> I've included the output of the build failure below.
> I don't see anything wrong with the linking command (hdf5 library is
> there).  I've double checked the exported symbols of hdf5.lib and it
> definitely exports the symbols that gdal complains it can't find.
> I get this failure on Windows 10 with Visual Studio 2008 and gdal 2.0.0
> through 2.1.0 RC4.  I suspect it might have something to do with HDF
> 1.8.16 (since the problem only manifested itself since updating HDF5).
> Searching this mailing list, I couldn't find similar failures.  Any help
> would be appreciated.
> Thanks,
> Ryan
> The compile fails with the following output:
>         cd ..
>         if exist gdal.lib del gdal.lib
>         lib /nologo /out:gdal.lib port\*.obj gcore\*.obj alg\*.obj
> frmts\o\*.obj ogr\ogrsf_frmts\ogrsf_frmts.lib ogr\ogr.lib gnm\*.obj
> gnm\gnm_frmts\o\*.obj   apps\commonutils.obj apps\gdalinfo_lib.obj
> apps\gdal_translate_lib.obj apps\gdalwarp_lib.obj apps\ogr2ogr_lib.obj
> apps\gdaldem_lib.obj apps\nearblack_lib.obj apps\gdal_grid_lib.obj
> apps\gdal_rasterize_lib.obj apps\gdalbuildvrt_lib.obj
> ogrsf_frmts.lib(ogrjmllayer.obj) : warning LNK4221: no public symbols
> found; archive member will be inaccessible
> ogr.lib(ograpispy.obj) : warning LNK4221: no public symbols found;
> nitf_gcprpc.obj : warning LNK4221: no public symbols found; archive
> cpl_recode_iconv.obj : warning LNK4221: no public symbols found; archive
>         link /nologo /dll /INCLUDE:OSRValidate
> /INCLUDE:OPTGetProjectionMethods  /INCLUDE:OGR_G_GetPointCount
> /INCLUDE:OGRRegisterAll /INCLUDE:GDALSimpleImageWarp
> /INCLUDE:GDALReprojectImage  /INCLUDE:GDALComputeMedianCutPCT
> /INCLUDE:GDALDitherRGB2PCT  /INCLUDE:OCTNewCoordinateTransformation
> port\*.obj gcore\*.obj alg\*.obj frmts\o\*.obj
> C:\Users\builder\Miniconda2\envs\_build\Library\lib\xerces-c_3.lib
> C:\Users\builder\Miniconda2\envs\_build\Library\lib\hdf.lib
> C:\Users\builder\Miniconda2\envs\_build\Library\lib\mfhdf.lib
> C:\Users\builder\Miniconda2\envs\_build\Library\lib\xdr.lib
> C:\Users\builder\Miniconda2\envs\_build\Library\lib\netcdf.lib
> C:\Users\builder\Miniconda2\envs\_build\Library\lib\geos_c.lib
> C:\Users\builder\Miniconda2\envs\_build\Library\lib\hdf5.lib
> C:\Users\builder\Miniconda2\envs\_build\Library\lib\libkea.lib
> odbc32.lib odbccp32.lib user32.lib                        ws2_32.lib
> gcore\Version.res  /out:gdal201.dll /implib:gdal_i.lib
>    Creating library gdal_i.lib and object gdal_i.exp
> gh5_convenience.obj : error LNK2019: unresolved external symbol
> H5T_NATIVE_DOUBLE_g referenced in function "bool __cdecl
> GH5_FetchAttribute(int,char const *,double &,bool)"
> (?GH5_FetchAttribute@@YA_NHPEBDAEAN_N at Z)
> hdf5dataset.obj : error LNK2001: unresolved external symbol
> H5T_NATIVE_DOUBLE_g
> H5T_NATIVE_FLOAT_g referenced in function "bool __cdecl
> H5T_NATIVE_FLOAT_g
> hdf5imagedataset.obj : error LNK2001: unresolved external symbol
> H5T_NATIVE_FLOAT_g
> H5T_NATIVE_INT_g referenced in function "bool __cdecl
> hdf5dataset.obj : error LNK2001: unresolved external symbol H5T_NATIVE_INT_g
> H5T_NATIVE_ULLONG_g referenced in function "enum GDALDataType __cdecl
> GH5_GetDataType(int)" (?GH5_GetDataType@@YA?AW4GDALDataType@@H at Z)
> H5T_NATIVE_ULLONG_g
> H5T_NATIVE_LLONG_g referenced in function "enum GDALDataType __cdecl
> H5T_NATIVE_LLONG_g
> H5T_NATIVE_ULONG_g referenced in function "enum GDALDataType __cdecl
> H5T_NATIVE_ULONG_g
> H5T_NATIVE_LONG_g referenced in function "enum GDALDataType __cdecl
> H5T_NATIVE_LONG_g
> H5T_NATIVE_UINT_g referenced in function "enum GDALDataType __cdecl
> H5T_NATIVE_UINT_g
> H5T_NATIVE_USHORT_g referenced in function "enum GDALDataType __cdecl
> H5T_NATIVE_USHORT_g
> H5T_NATIVE_SHORT_g referenced in function "enum GDALDataType __cdecl
> H5T_NATIVE_SHORT_g
> H5T_NATIVE_UCHAR_g referenced in function "enum GDALDataType __cdecl
> H5T_NATIVE_UCHAR_g
> H5T_NATIVE_SCHAR_g referenced in function "enum GDALDataType __cdecl
> H5T_NATIVE_SCHAR_g
> gdal201.dll : fatal error LNK1120: 12 unresolved externals
> NMAKE : fatal error U1077: '"C:\Program Files (x86)\Microsoft Visual
> Studio 9.0\VC\BIN\amd64\link.EXE"' : return code '0x460'
> Stop.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
