[gdal-dev] GDAL 2.0.2 & gpkg woes
Even Rouault even.rouault at spatialys.com
Sat Apr 30 08:00:24 PDT 2016
On Friday 29 April 2016 14:07:52 Alan Stewart wrote:
> My debug build of ogr2ogr.exe fails in exactly the same way as my
> application code fails. Apparently there's some difference in how the new
> GPKG code uses spatialite or expects spatialite to be built? The same
> libspatialite DLL works with our GDAL 1.11.0 DLL, but fails with the new
> GDAL 2.0.2 DLL.
Alan,
Never heard of similar issues. But you could probably try to upgrade to the
latest version of sqlite in the 3.8.X series. And/or upgrade your spatialite
version to the latest stable 4.3.0a.
Might be possible that the changes between GDAL 1.11 and 2.0 have triggered an
integration issue with one of the sqlite/spatialite versions you use.
Even
> Alan Stewart
> Senior Software Engineer
> TerraGo Technologies
> 3200 Windy Hill Road, Suite 1550W
> Atlanta, GA 30339 USA
> O.  +1 678.391.9615
> www.terragotech.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
